Question about Fisher and Paykel Dryers
When i turn our fisher and paykel dryer on it works for 1-5mins then turns itself off. Sometimes it shuts off completely other times it flashes as if on pause.
  • tania153 Jul 20, 2010
    This information was very relevant, i would just like a second opinion because as it is it would appear i would need to change the position of my dryer or get out a service repair man out.
  • tania153 Jul 23, 2010
    Tried the blow dryer trick but it hasnt worked so will price replacing control board.
    Thanks
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be the control board that has gone bad and needs to be replaced. However, before replacing the control board you can take the screws off and blow mild air on its back with the help of a hair dryer. If still the issue is not resolved then you’ll have to replace the control board. If you are good with these appliances then go ahead and replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 20, 2010
  • Fisher and P... Master
  • 12,061 Answers
You may have a sensor fault, or perhaps even a "Brain" fault, usually caused by power spikes etc. Please use the Service and Repair Manual at bottom, to troubleshoot, and repair.
However the only way to really tell is to use a service manual, to troubleshoot and repair your unit.
Below are a few self help, "How to fix" websites that you will find very useful. http://fixitnow.com/faq.htm#dryers
http://www.ehow.com/how_5347815_troubleshoot-fisher-paykel-dryer.html
Below is a website for spare parts. http://www.fisherpaykelparts.net/
Below is a generic service and repair manual. http://www.servicematters.com/maytag_library/docs/16026315.pdf
All lights flashing rapidly
Did you use a big hammer
That will fix it every time LOL.
Jun 29, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
How do take my fisher and paykel AD55 clothes dryer apart to check the if the belt is loose or not, because sometimes to have to manually turn the drum in order for it to start spinning again. Heat and...
sounds like the maybe the drum roller or motor, here is a video. Hope it helps Tim:
http://www.appliancerepairlesson.com/2011/03/05/fisher-paykel-dryer-access-3/
Apr 15, 2011 | Fisher and Paykel DEGX1 Electric Dryer
My fisher paykel dryer is 3 1/2 year old. It works fine on med and low heat. On high heat, it heats up too much and turns itself off
clean the dryer of lint inside and also the vent tube:
http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Nov 06, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and paykel clothes dryer wont turn with clothes in it.
Hi
Most dryers work with a belt around the drum. Either the belt is stretched and needs replacement or there may be a belt tensioner which needs adjustment to tighten the belt.
What is happening in your case is that the belt is slipping on the drum as it is too loose.
Best wishes,
Graemevm
Jun 18, 2009 | Maytag PYE2300AY Electric Dryer
Fisher & paykel front load dryer gone crazy!!!
sounds like a poltergeist..call in Ghostbusters..just kidding, really
that means your control board is really unhappy, and will need to be replaced..
May 25, 2008 | Fisher and Paykel Dryers
Open Questions:
Dryers Logo
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
