Question about Epson Stylus Photo R390 InkJet Printer
My printer epson stylus t10 wasted ink pad is saturated both ligths alternately flashing and the unit doesnt printing works
  • 526 Answers
The pads need to get replaced, and the unit needs to be reset.
estimated cost for parts and labor is about $80.
you can go to epson website and get emailed back a program to reset it, but you will need to read the disclaimer.
if you dont repace the pads, the printer will start to leak onto its surroundings
Posted on Jul 20, 2010
Epson says that the printer is malfunctioning and that I should get a new one. The green light is on and neither red light is on. However the printer refuses to print or even print a nozzle check.
Epson printers are built with a print counter, the company has predefined a maximum print no. for each model, If your printer is an old one,this could be a possible reason. If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can restore your printer to a working condition immediately by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
Sep 28, 2010 | Epson Stylus C60 InkJet Printer
The feed indicator light and ink light flash alternately (back and forth). the R800 won't print, allow cartridge tray to move, or feed paper.
Lights flashing alternately means that your printer's waste ink pad is saturated. It needs to be replaced and reset the counter. To reset the waste ink pad counter you will need a resetting program. You may download it by going to this link:
http://www.divshare.com/download/1140953-256
Aug 31, 2010 | Epson Stylus Photo R800 InkJet Printer
General error for epson stylus T10
green & red light blinking cant print epson t10
May 13, 2009 | Epson STYLUS R230 InkJet Photo Printer
I just replaced all 4 ink cartridges on my epson stylus c84 printer. The 2 left buttons on the printer are flashing and it will not print. I have tried turning it off and then on but it still won't print....
See the on-line handbook
http://support.epson-europe.com/onlineguides/en/sc84/index.htm
and look in Problem Solver, Diagnosing the Problem, Error indicators. If the two lights are flashing together, you have a paper jam. If this is the case, you should be able to pull the paper out from the front or top. If the lights are flashing together, and you can't see any paper jamming the printer, post a new comment to this effect for more help.
If the lights are flashing alternately (Unknown printer error), it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you should change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back with a new comment and I will provide further help.
Mar 06, 2009 | Epson Stylus C84 InkJet Printer
Reset waste ink counter on Epson C60 printer
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Feb 24, 2009 | Epson Stylus C60 InkJet Printer
Trouble codes - red and green light flashing alternately
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. If you want to have a go at doing this yourself, the 820 service manual can be downloaded from here:
810/820 http://www.mediafire.com/?m6ouftizois
Jan 11, 2009 | Epson Stylus Photo 820 InkJet Printer
Power light and red light keep flashing alternatively
If both lights are flashing alternately, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utilit to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
Nov 03, 2008 | Epson Stylus 680 InkJet Color Printer
Epson c46 printer
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C46 Service Manual". You will often find them for sale very cheaply on E-Bay.
Oct 19, 2008 | Epson Stylus C46 InkJet Printer
Epson stylus 830Uink pads full not printing help
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. Should you decide to have a go at changing the waste ink pads, the 830 service manual can be downloaded from here:
Jul 13, 2008 | Epson Stylus Photo 820 InkJet Printer
Epson C46 has stopped printing with message saying service needed but nobody wants to make it carry on working
If both printer lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
If you wish to pursue this matter further, report back.
Apr 12, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R390 InkJet Printer Logo
193 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
