Question about Bosch WFK 2401
Bosch WFK 2401 Door does not unlock after a cycle, stops at indicator "1"
My Bosch WFK 2401 is probably over 5 years old(don't know exactly since I got it from my previous home owner) and stops at the end of the cycle time remaining, 1, at any setting, and does not unlock.
The only way I can unlock it at this point is by turning it to "X" setting, turn the switch off, press both Start and Pre-Wash buttons simultaneously, then turn the switch on. This sets it to "00"(default)mode. I then turn the machine off, turn it back on after 5 minutes, then the lock finally unlocks.
The door also has trouble locking, not unless I slam the door shut a couple of times. Obviously there is something wrong with the door mechanism or door computer on/off/unlock/lock chip(?) Is this something I can fix on my own by replacing the door lock part? How do I even open the rubber part?I did find a part for the lock, or is this far more complicated, like the whole processor is gone.
  • Anonymous Jun 14, 2008
    Same issue with the door.
    Machine won't start unless slamming door shut and/or tapping the front of the machine...
    Has anybody solved this?  Please help :)
    Regards,
    Matt
  • Rob Edson Jul 20, 2008
    Door on my Bosch WFK 2401 has to be slammed repeatedly in order to get it to start.
3 Suggested Answers
  • 21 Answers
SOURCE: WFK 2401 DOOR does not open anymore
where is this machine i might be able to help over the phone
262-893-4840
Posted on May 02, 2008
barkencoa
  • 3463 Answers
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
I have a Bosch washer model WFK 2401 and I need a new pressure switch. The repair company I'm dealing with says that they can't get the part from Bosch any longer. Do you have any suggestions for...
We own a Bosch- probably nearly 20 years old. I manged to get the parts I needed- but we live in France and I buy on-line from the UK!
I would go onto the Bosch site. You will probably find spares suppliers from which to inquire. Also I'm sure you could query the Bosch site directly.
I'm not criticizing your repair company but I will be very surprised if the part was not available from somewhere.
Good luck,
John C
Feb 09, 2011 | Bosch WFK 2401
Our 9 year old WFK 2401 needs >$900 repair (drum bearing bad=needs both inner and outer drum; pump motor squeals.) But dealer says we must replace BOTH washer and WTA 3500 drier (which if fine) because...
yes he is right!!! ask yourself this,,,,after 9 years have you had your money worth out the dryer yet? and the washer???
go on treet yourself,,,buy a new lot,,,you know you wont to?
and what a slap in the face for all your friends,,,"look what i got!"
rasssssp!
Aug 28, 2010 | Bosch WFK 2401
Our Bosch WFK 2401 keeps filling with hot water - even when a cold cycle is selected.
The problem is the water inlet valve has failed. Although it is only the cold water the whole valve needs to be replaced. There are 2 solenoids on the valve 1 for cold 1 for hot the cold water solenoid has failed. The reason it works in the softner is it uses a separate solenoid to let water in there.
Check the below link , it might be useful;
http://appliancehelponline.com/washerwaterinlet.html
Jul 21, 2010 | Bosch WFK 2401
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
We have a Bosch WFK 2401 that is approximately 8 years old. I am not sure what cycle it was on when all of a sudden a loud noise started coming from the washer. Sounded like a gear stripping. A loud...
Check to see if inner drum is loose indicating bearing problem..Also check two springs on top of tub evident with lid off they can snap/ good luck
Sep 29, 2009 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
262-893-4840
Apr 23, 2008 | Bosch WFK 2401
Fault Code 06
put the selector switch on the x setting and hit the start button it will tak 60 sec and the door will unlock
Apr 19, 2008 | Bosch WFK 2401
Washing Machines Logo
89 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
