Question about RCA P52926 52" Rear Projection Television
It was wet under it
I had a fight with my dad and my tv was in his closet for 2 months.i think he sprayed somthing in my tv the top plastic housing was wet and there was liquid under that board.when i plugged it in the tv arched and the fuse on that board blew.i replaced it with a new fuse and that 1 blew to.it was wet under that board and i can see under the fagor restor black arch marks and also directly under it the plastic was burnt.i took the board out and it was wet under it.i found it on parts store but how do i be certain that thats the prob.
  • RCA Master
  • 8,617 Answers
If you saw arcing chances are that the board is definately fried. Just be sure the board is called the power/filter board if you dont have the proper number
Posted on Apr 21, 2008
I am fixing a closet in my home. It is part of an exterior wall and creates a lot of coldness in the house. How can I insulate this wall better? My kid is freezing at night she says. <a href
If you have enough room behind the stud wall install 1" rigid foam tape seams and then use the thickest possible roxsul insulation to fill the studs. Or axe the foam and install 6mil plastic on warm side of the wall after insulating tape all seams when done.
Jan 30, 2015 | Cam Spray Pressure Washer Foamer...
No water from spray on base
I had same problem. Remove all fluid from machine, I used a wet dry vac. As someone else said unscrew the 2 screws that hold the filter basket. Take out the filter basket and clean thoroughly. Find plastic hose that is now visible under basket and pull up and remove that (noticing where the slot is to put it back when finished) and pull the screen off top of hose and clean that as well. I then vacuumed out that hose with my wet dry vac. Reassembled everything and now works perfectly.
Oct 15, 2014 | Rug Doctor Mighty Pro X3 Value Pack - Blue
How do i clean the screen
take a mr. clean magic erasor get it wet and ring it out really well.
the front of the big screen tv will come off but its hard for me to expalin how to do it but there are two screws under the speaker cover u have 2 get off then ther r clips around the top check it out u will b able 2 figure it out
Aug 04, 2012 | Mitsubishi VS-50607 50" Rear Projection...
I want remove the battery before winter. how do i get at it?
Remove the seat , when you take it out . If it has cell check plugs for each cell ? take a look in each cell , fluid should be about 3/4 to 1 in from the top . If everything looks good leave your cell
plugs out . Put it on a slow charge for about an hour . Now put your plugs back in . Clean both terminals with steelwool and take some terminal spray and spray both terminals . You can get
this spray at the auto parts store . Also clean wire terminals on your bike , make them shine
and wipe down your battery box , and everything else under the seat . Take your battery and store
it where the temp stays about the same all day all night Like a closet . You can put it in a box
or plastic bag . Good Luck .
Nov 06, 2010 | 1981 Yamaha XJ 650
My 1999 Toyota Avalon has a leak that I can't find. When it rains the floor boards on the passenger side are both wet. I have a sun roof so how are the floor boards getting wet and how do I fix it?
There are 2 'weep' holes where tubes come out of the firewall and sometimes they get plugged. Get some compressed air and blow them out.
Also, inside the vehicle, there is a plastic pan that catches all water that might come down from the evaporator or leak from the outside into the interior of the car when the seal is not good between the firewall and the plastic pan that spans from the left to the right of the car under the dash board.
Get some expanding foam in a can and spray it up against the juncture between the firewall and the plastic water pan. This should seal out the problem if done properly.
Over time, the original foam seal goes bad and can actually flake away.
You mentioned the sunroof. Make sure that all the gaskets and that the sunroof does not leak onto the floor. This can be another source of wetness for your vehicle.
Try testing it by spraying water down from a hose to the top of the vehicle, or dumping a bucket of water all at once on the top of the roof. If it leaks, try using silicon sealant to seal any gaps that may exist in the sunroof.
Hope this helps.
Aug 17, 2010 | 1999 Toyota Avalon
Briggs & Stratton Stator Rusting preventing Lawn Tractor from starting. Took Engine apart after one month of having Sears replace the Stator and in the ''no start'' condition the Stator had quite a bit...
After a thorough cleaning, seal the surfaces that are exposed with Acrylic Automotive Top Coat or "Clear Coat". The acrylic base dries to a rock hard finish that is diaelectric in nature and will protect the surfaces it bonds to. Regap from flywheel as normal and this should fix it for two, three years if the machine lives under a tarp in the elements. :D
May 09, 2010 | Briggs & Stratton 50-Amp Automatic...
Hitachi 53uwx10ba, NOT a convergence problem
it sounds like somthing in the optical asembly is mesed up and vibration causes it to get worse
with all the problems i would segjust a new tv because old parts are sooo expensave.
Jan 22, 2009 | Hitachi 53UWX10B 53" Rear Projection...
I have the cash register Casio PCR265P
Hi. Standard problem with this kind of printer. The rotary switch gets dirty. If you want to try fixing it yourself, unplug the machine, remove the screw inside the printer compartment that holds the machine to the drawer. Slide the whole top section forward on the drawer, then lift upwards to remove the cash register from the drawer. Gently turn it over so you can see the bottom side of the printer. On the printer, you will see a black plastic housing at one end with little wires going into it. This is the switch housing. Get a can of general purpose luricant (such as WD40) and spray into the black housing. Try to get the spray into any little gap in the housing, or under a corner. I don't recommend unclipping the housing as it can be difficult to reassemble. Just get the spray generally inside it as much as you can. Don't be afraid to get the spray on other areas, it won't harm it. Your paper might be wet for a few prints that's all.
Once you have sprayed it, plug the machine in and try it. Sometmes it takes a few sprays and on off cycles before it works, but it will usually do the trick if there is nothing else jamming the printer.
Mark
Dec 28, 2008 | Casio Parts Cash Register PC Desktop
Wet/dry Panasonic shaver stopped
My model is almost the same as your model ...
Problem: Model ES7037CMB - Over the past month the Panasonic shaver would turn on with 3-4 tries, but now will not turn on at all – the on-off switch must be bad after only 7 months of wet use. Before sending in I found this diagram:
Disassembly: Remove bottom Phillips screw & end cap, pop off each plastic side with fingernails (reinstall them from top 1st), remove 4 screws, remove 2 clips, take top off. Remove battery case and the on-off little, white plastic lever fell out. Slide off the white plastic/metal on-off slider & clean contacts with knife … my bottom contact was black & top was clean.
Assembly: Reinstall on-off slider (white plastic with metal contacts) by sliding back in grooves -- hardest part - place the on-off plastic lever on the battery back unit – I tried to put it on the case and could not get it to stay on. Slide the battery pack back in with the plug prongs in the holes in the end being careful not to drop the on-off lever. Test shaver. Stuff battery wires inside case – screw 4 screws and add 2 clips on, then final screw in the end after cap placed on. Easy once I knew how to put the on-off lever on the battery side – that was tricky. Total time was about 1 hour – next time it will be about 15 minutes. Works great! jgg 12-27-08. Think I will use it dry from now own since it had a lot of whiskers inside of it and maybe wash only the head as needed with baby shampoo.
May 30, 2007 | Panasonic ES 8077S Electric Shaver
RCA P52926 52" Rear Projection Television Logo
52 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
