Question about Refrigerators
No water coming out of dispenser on outside of door
  • 4,070 Answers
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Posted on Jul 20, 2010
Samsung French door ice maker
Sounds like you are getting to much water or the sensor is not Sensing proper temp
Apr 02, 2016 | Samsung Refrigerators
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
Water leaking outside of fridge
Do you notice if the water was coming from the dispenser door area or from underneath the unit? Did this unit recently go into a defrost cycle at all that you might know of?
Aug 22, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water not coming from gss25lgmb bb
I have a GSH25JSRFSS GE refrigerator. Twice, the water line has frozen near the dispenser. Each time I used a hairdryer to heat either the side of the door where the water line runs and blew hot air up the dispenser. This last time, I took the plastic cover off the outside of the door (it clips on) and blew hot air into the small holes in the door that the outside grate clips into. This allows the hot air to get inside the door, and I heard ice from the frozen line drop. Subsequently, the water line worked. Two points: I did have water running to the line in the bottom of the refrigerator, so I knew it was an ice clog, and secondly, I took care not to blow hot air on the exposed wires inside the door.GKAZ
Oct 23, 2011 | GE GSH25JSRSS Stainless Steel Side by Side...
The outside door water does not work
Can I assume the ice and water are activated by two different switches? The ice switch activates the motor that dispenses ice. The water switch activates a solenoid that opens to dispense water. If you can, find the solenoid and make sure it's not stuck closed (tapping it with a screwdriver handles usually help persuade it a bit). I would tap the solenoid while pushing the water button. Listen for the solenoid to activate. If you can't activate the solenoid, find the switch and depress it with a small screwdriver. Usually, these switches are just simple little microswitches that need a little cleaning and coaxing
Feb 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I get the water dispenser on the outside of the door to quit dripping water
Probably replace the water inlet valve on the back where the water supply comes in. Disconnect the water line to the dispenser there and see if it keeps dripping when you try the dispenser.
Jun 30, 2009 | Whirlpool ED5FTGX Side by Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
Filtered water
the water line that run through the freezer door is frozen. its been a common problem on the GE built refrigerators. (that who built yours for sears) dis connect the water hose hehind the kick plate below the freezer door. use a hair dryer to warm up the inside and outside of the door around the dispenser area to defrost the line. it will take anywhere from 15 to 30 min to get in completly defrosted but it will once it is defrosted
Nov 24, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
