Question about JVC AV-48WP30 48" Rear Projection Television
Fixya issue I just had the same issue as yours happen to my JVC today, I get a clicking sound as if it is trying to turn on, then a thumping from the speakers. Were you able to fix the issue?
I have ordered the ic's and will post if it solves the problem
Posted on Apr 23, 2008
Sound system makes a thump thump noise
Your speaker is now blown.. Replace the Speaker and you will get sound back instantly. Happened to my Drivers Speaker last week, replaced the speaker and life is good again.
Mar 01, 2014 | 2010 Kia Soul
128 OAKLEY THUMP
cheak for firmware update online for it 1st
Jan 31, 2008 | Oakley Thump MP3 Player
ABS Brake failure light
It sounds like your ABS modulator is failing. It will probably need to be replaced. You could also try and flush the brake fluid to see if it will resolve the issue.
Jun 19, 2017 | 2003 Volvo S60
Our JVC 56in rear projection tv cut off and when we tried to turn it back on is makes a thumping sound and the blue light on the front blinks and the thumping sound gets louder... Help??
The problem is one of the video drive IC's on the crt boards is bad. These IC's are located behind the front speaker grille. The board connected to the bottom of the crt's will have these ic's on them. They will be screwed into a metal "heatsink" The part number is TDA6111Q
Nov 28, 2008 | JVC AV-56WP74 56" Rear Projection...
No sound, no picture just clicking
Horizontal output transistor is faulty .
replace it.
Gopal
Nov 30, 2007 | JVC AV-30W475 30" TV
Where is the deflection board
Was there a change in symptom from original?? Then recheck
your soldering with meter....short circuit???? Let me know...T.
Nov 16, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74
havent had time to check these things out but here is some raw research I have done
No. The CRT driver ICs are prone to shorting and cause this symptom (I just had one with those very symptoms and the green CRT driver IC was shorted). Disconnecting the CRT board does not clear the short on the board. Often then is a small burn mark on the CRT board under the affected IC (but not always). The IC should be a TDA6111Q. Be sure to note the proper position
of the IC as it should face with the letters TOWARD the heat sink!!!!
Larry, Check the CRT driver ICs on each of the CRT boards.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxx
Hi Guys, I don`t see many JVC`s and don`t have the print for this AV48WP30, went out this morning and as customer claimed on phone when you plug set in and turn on it makes a loud thump thump in both speakers 20-30 times then relay clicks, the thump stops, and blue idiot light on front goes dim/bright, dim/bright, have to unplug set to start this same scenario over again. Never develops HV or audio, Will order the service manual today, but would like to know if anyone has seen this before (should say "heard" this before)
I would disconnect each crt board and hv lead one at a time and try. Have seen several bad tubes on that model. The only other problem I have seen on that set is bad convergence amps, however that doesn't cause shutdown.
Perry Bower
Electric Medic
From Tech Repair CD:
JVC\AV48WP74\just went click*click*click when turned on Video drive IC (IC1101) on the red CRT module
shorted. It looked like bad solder on the B+ was the cause
Frequently Used Top Five Repair Parts by symptom code
MODEL NUMBER : AV48WP30 - TV
SYMPTOM CODE : DEAD
TOP FIVE PARTS :
2SC5552-RL
2SC5904-RL
QQH0113-002
STR-F6629B/F7
STK392-110
Above from JVC Web site, also I have seen shorted video drive IC's on the crt boards short and cause this symptom. Try unplugging the 200 volt source to the crt boards and see it the set powers up and stays on. There is a B+ relay which supplies 130 Volts to the horizontal output circuit. Is this relay energizing? I takes about five seconds after the power is turned on for it to energize. If a short is detected on the 130 volt line the blue power lamp on the front will do what you describe and the relay will pulse on and off. (David)
Symptom:
Non-functional Digital Input
Solution:
1. Power off the unit
2. Disconnect the digital input if it is connected
3. Remove the rear cover
4. On the digital input module, using a shorting pin (PC type) or a
jumper, short Pin 1 and Pin 2 of the
SB connector
5. Power on the unit
6. Unplug the unit and remove the shorting pin or the jumper
7. Re-attach the unit’s rear cover
8. Power on the unit, and input the digital source
Oct 10, 2007 | JVC AV-48WP74 48" Rear Projection...
No responce except thumping noise
PLEASE TRY TO CHANGE AGAIN THE CONVERGANCE IC'S
Oct 02, 2007 | JVC AV-48WP30 48" Rear Projection...
Thumping sound from all speakers
Ever find the cause of this? I have the same problem. Thanks Steve
Jan 21, 2007 | JVC TH-C5 System
JVC AV-48WP30 48" Rear Projection Television Logo
79 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
