Question about Refrigerators
Ice maker stopped making ice, freezer side not getting cold and frosting up, would like to know just how this unit is Serial number 162D6295G046
  • Anonymous Mar 25, 2014
    Need serial number to replace
    Genius:
  • 1,073 Answers
Loos like samsung serial, can tell you that you have a defrosting problem unit will not make ice if freezer temp is above 17 degrees f
Posted on Apr 21, 2008
Ice maker is not making ice and water leaks from bottom.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Ice Maker
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 21, 2009 | Hotpoint HSS25GFP Side by Side...
Too much water coming out of the pan (in the front of the ice maker) and copper pipes on top left side are covered with ice.
Not real sure just what you are saying as to what pan? The copper pipes that go to the evap plates where the ice is made are supposed to frost over. They get colder than dew point of the air so this is normal. But all the pipes should frost. Does the unit shut down and give any type of beeping noises? This would be the control giving you a trouble code. You may have a water valve leaking. Turn unit off and see if water continues to run. All water should stop within a few seconds. Let me know what you find. Please verify model and serial numbers.
Aug 13, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Apr 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerator failed keeping food cold, ice maker stopped working
i would look on the back panel of freezer section, is it iced over???? either its iced over and you have a defrost issue, or if there is no frost at all behind the rear panel yo uhave a sealed system/compressor issue
Nov 15, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Freezer keeps running
yes,you need to pull the front panel on the ice maker off to get to the solinoid that opens and closes the flap,with the flap vranked open you are letting cold air out and warm air in and that makes frost,if you don't want to try and fix it your self put a cloth towel in the chute to block the air lose and call an honest local appliance repair person-mike
Nov 15, 2008 | Whirlpool Refrigerators
Freezer not cold, the meat is melted
Sounds like you have a defrost problem. Pull the back panel off inside of the freezer and make sure the fan is running (evaporator fan motor). If it is, check the defrost heater and defrost thermostat for continuity. If one is bad, you have found your problem. If both are good, replace the defrost timer, adaptive defrost board, or main control board (I'm not sure which you have since I don't have your model number). Let me know if I can be of further assistance.
Mar 27, 2008 | Kenmore 53542 / 53544 Side by Side...
Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Oct 10, 2007 | Kenmore 53542 / 53544 Side by Side...
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
167 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
