Question about Cameras
I have a soligor 24d flash and it no longer works
I have a soligor 24d flash and it no longer works no power -i changed batteries still doesnt work-there does not appear damaged in any way do u have suggestions or have address where i can send unit 4 repair
the unit worked approx 2months ago-when i press test button i get nothing
SOURCE: MS-1036 doesnt sense power cord attached
You hit exactly on the head with don't move the unit when plugged in - there are many people with the MS-1036 having this problem if you search the web. MSI does cover the bare-bone itself, however this falls into that damaged not defective area. Many shops would replace the entire board, making it costly as looks you had done once already. Good idea is to look to Asus 17" bare-bone and move your items over, much better made. Citrus Micro - see you worked with them, so have I, always had good luck with them, they make great contact and sometimes too honest, prices are great to - like any etail store with returns, manufacturer warranty tells most etail stores how they are to handle things. Could be why you see them getting rid of selling MSI products? Looks like you found the best idea, take to walk in repair shop - hard to beat that or again, buy new bare-bone.
Posted on Sep 07, 2007
SOURCE: Flashing auto check and test/charge
This means that your batteries are low on power.
Posted on Oct 07, 2007
CanadaBruce
  • 58 Answers
SOURCE: May I use a Soligor 24D Flash on my new Nikon D40X Digital Camera
You can purchase an off-camera flash sync adaptor at any good camera store, complete with extension cable.   The should work fine.
Posted on Dec 06, 2007
SOURCE: Flash
i think the firmware is corrupted ..... you must install new firmware ....
just visit the nearby showroom or technician he will install the new firmware ..........
for installing firmware it may costs some 300 to 400 bugs ....
how ever there may be other problems too may be the battery is dead just change battery and check....
check whether it is detecting in pc or not..........
Posted on Feb 11, 2008
SOURCE: lkd-24d error for starplus sts
The technician had to remove the memory module as the board tried to reset itself but the memory module was corrupted and would not allow the board to reset itself. The phone were reprogrammed and are working.
Posted on May 13, 2008
LKD-24D V0.6J SCOUT-DX V1.1 NO SYNC
If power cycling does not work, the next step would be to reinitlize the phone system. Caution, this will erase all programming and revert back to factory default. I have found over the years that the STSe Database can get corruppted and cause this display read out. If power cycling does not fix it this usu does. If it does not then there is a motherboard issue. Good Luck.
May 27, 2014 | Vodavi Starplus STSe Universal KSU 3501-01
Soligor telescope user manual
A user manual for what model Soligor telescope?
Jul 25, 2013 | Cameras
Soligor telescope manual
What model Soligor telescope?
Remote doesnt work anymore
Fan remote stopped working. New battery installed.
Apr 14, 2013 | Lakewood HV 18-c Floor / Box Fan
I HAVE A SOLIGOR 2X CONVERTER AND I NEED A NIKON ADAPTER IS SUCH A THING AVALIBLE
There are a lot of adopter rings available. But most will turn the combination into a MF lens. Most non Nikon tele convertors, only can be used in MF when put on a Nikon camera, so I don't think you lose a lot when you find a Soligor Nikon adopter ring.
Sep 22, 2012 | Pentax Soligor Auto 2x Tele Converter For...
Soligor C / D 7 2X MIRROR CONVERTER TO NIKON MOUNT
The Soligor C / D 7 is a tele convertor. If you want to use it on a Nikon, I hope you have the correct connection. Your question implies you are planning to using this with a mirror lens. Most miss or lenses, come with f/1:8 and the convertor will make that to f/1:11. Most cameras only can auto focus till f/1:5,6, so when using this, forget auto focus, because that won't work.
Sep 22, 2012 | Sony 2x Teleconverter
Cannot power on, even when plugin the AC there's no lights (no charging)
Hello
This is a power problem.
First remove try charging your laptop with another power cord to see if it works
If it doesnt,remove the battery from the laptop and plug the laptop directly into power if the laptop comes on,then the battery is faulty and you should get a new one
But if it doesnt then the charging port is no longer working and you should get a repairer to help you change the charging port
Thank you for visiting fixya
Mar 06, 2010 | Gateway MT6707 Notebook PC
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Soligor mirror 500 on Nikon D-80 ????
The D80 is not able to set exposure with non-CPU lenses like your Soligor, so it probably is very far off on the correct exposure. You must operate in Manual mode and choose a shutter speed appropriate for the lighting. Reflex (mirror) lenses have no aperture adjustment, and I'm guessing your Soligor 500mm is probably f/8 like just about every other 500mm reflex. A good starting exposure for a typical sunlit scene would be 4x your ISO setting. For example, at ISO 400 set your shutter speed to 1600.
Mar 08, 2009 | Samyang 500mm f8 Ultra Telephoto Manual...
Nov 28, 2007 | Nikon D40x Digital Camera
Cameras Logo
69 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
