Question about Onkyo TX-DS595 Receiver
My Onkyo TX-DS595 will not output any sound. On FM I can hear static(no ant hooked up) I get no sound form CD or Video 3 where my tv sends an optical signal to optical 2. The display shows that PCM digital is coming in but no sound out. Could some protection circuity have activiated? If so how do I reset it? Thanks
  • ylimor Aug 14, 2010
    I can receive FM signals and sound does come out through the receiver to the speakers in
    FM mode. I cannot get any sound to come out from CD or Video3 to the speakers. The reciever does indicate a PCM signal in Video3 but no sound output from the speakers. Thanks for the help
SOURCE: HDMI SOUND
True HD can only work with HDMI interface and is only available on some newer HD DVDs. Check the DVD to see if the True HD encoding is available.
Posted on Feb 13, 2008
SOURCE: Onkyo TX-DX838
I went back and found a loose cable/coax. Re-attached and now the receiver works as good as ever.
Posted on Nov 25, 2008
taran_2005
  • 10515 Answers
SOURCE: No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Posted on Jan 24, 2009
  • 4234 Answers
SOURCE: garbled / feedback sounds from powered subwoofer
The surround processing portion of the unit has a problem. In either stereo or direct mode, the digital procesing is bypassed. This could be just the surround processing IC, but that IC may not be available as a separate part. I would suggest that you bring this unit to an authorized Onkyo service center for an estimate.
Dan
Posted on Mar 18, 2009
marsrover
  • 682 Answers
SOURCE: Onkyo TX-SR701 no Digital output sound!!
befor go to any direction please repeat your system setup as manual told you(for digital output setting)
Posted on Apr 09, 2009
Onkyo tx sr502vreceiver wont send sound out when trying to play a cd. Hooking up to samsung smart tv that has no s video or optical output connections. HELP ! ! !
Hi Denni, the TV should not be a factor. Is the CD player connected to the receiver. It should be playing out the receiver speakers. Thank you, Onkyo USA
Nov 30, 2016 | Onkyo Audio Players & Recorders
Wire diagram for surround sound
http://static.fixya.com/Manuals/O/Onkyo/TX_DS595_5_1_61851C3AAA3EA98913A226B1F1FDDAD1.pdf there is the manual for your unit
May 08, 2011 | Onkyo TX-DS595 Receiver
I have a sony bravia TV with an optical audio out. I have plugged the optical cable from the tv out and into the DVD optical 1 input and receive no sound? I have setup the audio to optical 1 and still not...
Most of the old Sony TVs released before 2007 has an issue with its optical output. only when you use a direct cable connection to its VHF/UHF input, the optical outputs audio. Otherwise, you have to stick on the A/V connection to receive the TV audio though sound system. Please get back to me with the model # of the TV so that I can check whether the TV comes under the category.
Thanks for understanding.
Feb 22, 2011 | Onkyo TX-DS595 Receiver
[TX-DS595] My Video 1 stopped working, no audio, (Right before the super bowl!) yet I get audio on DVD & Tuner. What could be the problem? Thanks, Ira S. Cohen
Well, what's on Video 1 and is IT okay?
You don't say if you're using the analog audio associated with Vid 1 or if you have digital audio coming in and assigned to Vid 1. Check the cables. If using the optical, make sure it has no small-radius bends.
If analog audio, try another input - video 2 or 3.
If you have Cable/SAT TV as the source, what's going on with ITS audio settings?
http://www.retrevo.com/support/Onkyo-TX-DS595-Receivers-manual/id/365dj195/t/2/
You can always run that RCA cable pair from the source to theTV as a test for audio, too.
Feb 05, 2011 | Onkyo TX-DS595 Receiver
Hi, I own an Onkyo TX-DS595 amplifier and use it for several setups: Playstation, DVD and TV. I'm using the optical output from both my DVD-Player and my Playstation and I recently noticed, that there's...
So they swap between left and right? Maybe there is a short in the speaker wire. Also, there may be a short in the optical plug. Try using the analog RCA and see if it happens there. It may just be the optical plug. Try cleaning the tip with lense paper. You want this because as you may know optical means light, and optical plugs use light to command the stereo to play instead of electricity. So if the tip is dirty, it may be not getting all the signals.
Oct 11, 2009 | Onkyo TX-DS595 Receiver
Garbled / feedback sounds from powered subwoofer
Dan
Mar 18, 2009 | Onkyo TX-DS595 Receiver
Hooking Ipod to onkyo receiver
i pods use a different adapter for doing this. It plugs in the bottom using the big porton bottom and outputs the rca plugs this way. Ipods see too much resistance and protects the unit from burning out. check this out http://www.amazon.com/Logic3-iPod-RCA-Phono-Cable/dp/B00083D7WC
Feb 21, 2009 | Onkyo TX-DS595 Receiver
Can I connect an ipod to Onkyo tx-ds595?
I connect my iPod to my Onkyo using a stereo cable with mini-plug on one end and RCA L&R outs on the other. Just plug the RCA plugs into the AUX or TAPE IN on the Onkyo, and the stereo mini plug into the iPod and play as usual.
Aug 21, 2008 | Onkyo TX-DS595 Receiver
Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
May 06, 2008 | Onkyo TX-SR605 Receiver
Onkyo Zone 2 problem
The zone 2 will only play analog sources - so  you must hook up the output from the tv/cable/dss on it's analog (RCA Jacks) into an input on the Onkyo.  You might also have to enable this output from you tv/cable/dss.
Mar 25, 2007 | Onkyo TX-SR700 Receiver
Onkyo TX-DS595 Receiver Logo
230 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
