Question about Microsoft Xbox 360 Console
DVD Drive malfunction
My son accidentally managed to get 2 disks in the tray on their vertically oriented 360. Now we can tray in a single disk, but it sounds like it is slipping and won't spin up. Is it likely the spindle would suffer permanent damage from this? Is it something that could be adjusted if I removed the drive?
    Problem Solver:
  • 9 Answers
i cant see any real serious damage being caused by inserting 2 discs, however we are talking about the xbox 360 here and the disc drives have had many problems amungst all xbox versions.
Regardless of your warrenty the xbox repair center should fix your xbox free of charge for you providing you dont tell them that your son may of caused the problem. because whether he did or not, they will assume he did.
It could just be a coincidence this happened when the 2 discs were inserted or it could of actually caused the problem.
if you really want to try and fix this yourself, check the dvd drive and make sure that the spindles center and the top disc latching part are correctly alligned.
the top part should be loose and will move freely, the main lower spindle near the laser should not spin so freely and if you spin it you shoul dbe able to feel if it is firmly attached to the motor or not.
Hope This Helps
Anthony Kinson
Posted on Apr 22, 2008
Hi, I have an Xbox 360 with a Samsung DVD drive. This is kinda embarrassing that I have to ask for outside help, as I specialize in Xbox 360s, but I've been racking my brain for a month now and i still...
you could try heating the magnet up then cooling it down apparently the magnet would still be magnetized once cooled down but would not be as magnetic
hope this helps
Apr 01, 2011 | Toshiba Samsung TS-H943A Replacment DVD...
I switched disk drive from 360 to 360 and now it wont play dvds someone please help!!
the issue is with in the swapping. The system inbedded a security code that is only identify by that single xbox360. In order for your system to recongize your disk drive in another xbox360 is if 1. the diskdrive is replica of the one swaped then only the chip under the drive is needed from that system or 2. flashing the disk drive. **BOTH ARE ILLEGAL**
you can manage either one by googling flashing xbox360 diskdrive ______ <--- the type of diskdrive you swaped out.
Mar 17, 2011 | Microsoft Xbox 360 Console
Xbox 360 says insert disk when a disk is inside. Reopen tray and insert disk, and it still says inert disk
I ran into this problem once myself. Try altering the orientation of your XBox360 (i.e. if it's vertical, lay it flat & vice versa)
Feb 27, 2011 | Microsoft Video Game Consoles & Games
Hello, for some reason my Hitachi HTS542525K9SA00 DVD drive is not working. It will open and close but does not show up in the computer section. It shows that it is working porperly in device manager and...
roberts_mich
If you drive is not showing up in My Computer but is showing in Device Manager you may need to reasign a drive letter to the drive. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
If you if does not fix the problem they you could have a Windows/driver problem or a hardware problem. I would try to connect the drive to another port on your computer and/or try the drive in another computer. If it works then you may have a motherboard or Windows problem.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Dec 20, 2010 | Hitachi HTS542525K9SA00 250 GB SATA Hard...
Xbox disc reader does not think a disc is in tray for xbox 360 games
This is a common issue.
1. Make sure your disk is clean. Dirty disk can cause disk reading issues.
2. Clean the drive with a CD/DVD laser cleaner.
3. Replace the laser. You can get a replacement from Ebay for $10-15. Make sure you get the right one for you drive. There are several different models.
May 09, 2010 | Microsoft Xbox 360 Console
XBOX 360 "Open Tray " message
Your CD/DVD drive has failed mechanically. Usually this is a physical problem where the disc is simply no longer in alignment with the laser. It does not necessarily mean something will make noise, and can be just one small part slightly bent or broken so the disk now moves freely top to bottom.
If you can do a warranty repair, you're set. But if you are no longer under warranty, you only have two options. you can try and replace the drive, which although odd shaped; I think is just a standard IDE drive, or you can shift the XBOX 90 degrees to Re-orient the box. In some cases this may let gravity hold in place what the internal mechanisms no longer are.
Mar 15, 2010 | Microsoft Xbox 360 Console
Xbox 360
Most likely your disk or dvd drive is dirty. Run the disk through a disk cleaner and run a dvd cleaning disk through your drive.
If that dos not work, try removeing disk, close drive, turn off console, unplug power supply, wait 10 or 20 seconds, then reconnect power supply and try again.
If that fails, assumeing other disks will read, your disk may have a major flaw. You can check with your local game store, they often have a machine that may restore your disk, (most places that I know of charge like 1 or 2 $).
Mar 10, 2010 | Microsoft Xbox 360 Console
The x 360 won't read disks. Why? It says reading, reading and then open tray.
Most likley, either your disk or dvd drive is dirty. Try a dvd cleaner to clean the drive and a cd/dvd cleaning cloth for the disk. also try turning off the console and unplugging the power cord for about 60 seconds or so and then restart and retry.
Mar 04, 2010 | Microsoft Xbox 360 Console
Problem reading disk
It needs the laser or the dvd drive replaced. We can do this for you. We are a registered repair service on this site.
www.videogamerepairservice.com
Feb 20, 2009 | Microsoft Xbox 360 Console
Xbox 360
When your son knocked the console over, he may have broke a component connecting to the disk drive, especially if the console was on.
Apr 11, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
79 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
