Question about Phoenix Gold ZBIS-92C TTL Flash
Some of my flashes double flash some single flash
  • kakima Jul 20, 2010
    Is this affecting your photos? Often the first, pre-flash is to allow the camera to meter the proper exposure and flash output.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Phoenix Gold Master
  • 102,366 Answers
Having gone over a month without a response, I assume this is no longer a problem.
Posted on Sep 17, 2010
Alarm went off but no smoke was found and no other smells were detected. I do not believe that there was CO present. All the units were activated. after a period of time they stopped. This occurred 3 times...
http://www.kidde.com/Documents/User-Guide-900-0102-A-ENG.pdf Remember that smoke take presidence over C/O detection so notice whats going off first . LED Indicator Operation
Red LED
The red LED will flash as described below under the following
conditions:
--During smoke or CO alarm, with every beep
--During testing (same as alarm)
--Low battery, single flash with chirp
--End of product life, double flash every 30 seconds with chirp
--Unit error mode, single flash with chirp
--Unit error mode, a Fault Code is flashed every 30 seconds (can
be observed and reported to customer service for
troubleshooting. Above is the user guide.
Sep 09, 2013 | Kidde 9000102 Night Hawk Combination...
Www sony
When you activate Red eye reduction mode(eye icon) it will fire 2 flashes and when you keep it only flash (thunder icon) mode then it will fire 1 flash
May 16, 2013 | Sony Cyber-shot DSC-W710 Black
Flashes f1 with a wrench and motor is spinning fisher&paykel double dishwasrer
This video explains how to repair your double or single drawer dishwasher.
http://www.appliancerepairlesson.com
Aug 29, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Problem with 2003 1.6 scenic....
try reseting the system, disconnect the car battery for 10 to 15 minutes.......just be sure your car radio is not a coded one, or have the code ready if it is
Jul 27, 2009 | 2001 Renault Sportwagon
Kenmore double oven flashing "door locked"
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Need help
You can record to any DVD disk. The only difference between single layer and double layer is the amount of information you can put on the disk.
Feb 18, 2009 | Mitsuba DV9002 Flash Media Camcorder
RED FLASHING LIGHT TV BLACK
does the television stay on ? these codes or flashing lights and designed to tell you about a problem that the internal computer had detected - a single flash then a double flash is a software upgrade notification -- call support at customer service and they will tell you exactly what the flash is related to then you can find the fix or repair with more information
Jan 25, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Change ringer tone
Message/Ringer Lamp: The Message/
Ringer lamp informs you visually that you
have a message or a call.
When you receive a call, the lamp
flashes depending on the ringing pattern.
When the ringing pattern is set to Single
(Slow flash), Double (Moderate flash), or
Triple (Rapid flash) in your PBX, the lamp
flashes. When the other ringing patterns
are set in your PBX, the lamp may not
flash. (e.g., S-Double, Call Waiting
Tone1).
When someone has left you a message,
the lamp is lit continuously.
Please note that the above indicates that ring patterns are set in the the PBX. These are issues that require a real person to sit at the main system and program the features that users need. I hope you have an I.T. person that knows your phone system. If you don't, you'll have to find a communications company in your area that can program your system. Thanks for using Fixya.
Jan 19, 2009 | Panasonic KX-T7730 Corded Phone
BLINKING LIGHTS ON fURNACE
had same problem, first you need to find the location of ignitor double black wires from plug on board and flame sensor.single red wire. 4 red flashes means ground fault, I removed ignitor, cleaned with some scothchbrite, cleaned around screw holes(2) to reestablish ground, I even ran a wire from one of the mounting screws to a ground elsewhere. then I went on to the flame sensor witch will give you flashing yellow light. single red wire to sensor that has one screw holding in. Remove sensor carefully and do the same as the ignitor, clean with scothbrite. I did this a year ago and is still going!
Jan 21, 2008 | Dishwashers
Phoenix Gold ZBIS-92C TTL Flash Logo
21 people viewed this question
Top Phoenix Gold Cameras Experts
Are you a Phoenix Gold Camera Expert? Answer questions, earn points and help others
