How to hook up vhs to dvd to tv.I dont have any instructions books vhs is old type VR6548/75L
  • 1198vinnie Apr 22, 2008
    NO INPUT ON DVD ... THANK YOU, VINNIE
  • 123 Answers
Does your VHS have av jacks on it?
If so, connect the av jacks (red, yellow, white) from the output of the VCR to the input of the DVD and then from the output of the DVD to the input on the TV.
This will only work if you have input on the DVD. Recordable DVD players do, but a lot of the older ones don't.
Good Luck.
Posted on Apr 21, 2008
I have an old emerson TV/VCR (Digital Tracking VHSHQ) The TV works fine, but when I put a tape in it is ejected and part of the tape stays inside, but can be pulled out.
Try a VHS Cleaning Tape Cassette. Follow it's instructions. If no better result it's not worth throwing away money on having repairs done but better put toward, if you can afford to, buying:
Option 1. A VHS/DVD player (combo as these are known) and plug that into the Emerson AV input.
Option Two: A VHS/DVD twin recorder combo deck - and plug that in.
Then start on copying any VHS tapes you cherish to DVD on this device.
Option Three: Forget the Emerson except for just using as a TV and buy a new TV with DVD player built in - the latest type of combo.
(I'm having to guess whether you've just used tapes to watch or record and watch)
Sep 26, 2011 | Televison & Video
I dont really know whats wrong with it when ii try to get it to copy a vhs to advd it wont work?
I don't know what recorder machine you have or what your hooking up to do your transferring. You cant convert VHS movie to DVD by plugging in RCA jacks from VHS player to DVD recorder. DVD reads digital and VHS does not because it reads analog and out put analog. you have to covert VHS movie into digital in order to transfer to DVD. There is a program you can buy call Roxio Easy. great stuff, cost 59.00 buck for your desk top computer, everything you need is there to transfer VHS to DVD...hope that help some, good luck.
Jul 12, 2009 | Memorex MVDT2402 24 in. TV/VCR/DVD Combo
DV1130 hooked up to TV, DVD works great. VHS has
If you are using RCA cables (Red Yellow White) the video (yellow) could be bad or not in the connector all the way. When the VCR mode is selected try pulling the yellow connector out then back in and see if anything changes on the tv.
If you are using another type cable let me know and I will help you diagnose.
Hope this helps
TankMurdock
Apr 25, 2009 | GoVideo DV1130 DVD Player/VCR
Old TV and old DVD player
Make sure your TV is "tuned" to the proper input. To change the input, change the TVs channel below 02, find the "input" dialoge on the tv's menu, or press the "input" or "video" button on the TV or Remote.
Repairing a 20 year old VCR (By chance a BetaMax?) is not worth your time. Replace it with a $60 DVD/VHS combo unit.
Mar 12, 2009 | Televison & Video
Poor viewing with VCR
how do you have the combo connection and dish network hooked to the tv ? if you have an s-video , yellow RCA jack video or component video hooked to the same input then it will act this way, because two inputs cannot be on the same video input # on the tv.
is this what is happening? or how are you connecting it?
Jan 04, 2009 | Samsung DVD-V4600 DVD Player/VCR
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Hello, I need your help!!!I would like to use my camcorder to play the VHS-C tapes. But if that won't be easy to explain to me, or it won't work, I do have a TV sitting beside my VHS recorder and it sits...
Is your vcr hooked up to your tv? Is your DVD player hooked up to your tv? If you tell me your camcorder make and model# and your vcr make and model# I'm sure I can make it sound fairly simple for you. So tell what is already hooked up to the tv and what you want hooked up and I'll do the rest. Give me make and model # of your tv too please. Whatever you want, you got Kay! Just let me know the answera and we're there Kay!
Apr 11, 2008 | GoVideo R6530 DVD Recorder
Dvd recorder
Following the instructions on hooking up the cables gave me fits. I finally just put the instructions away and winged it. Got it that way. Bypass your Ilo tuner. Hook the Comcast Cable (outs) up to the A/V input 1 of your ILO. Hook your tv combo A/V outputs, to the ILO A/V inputs. Select the Source and choose the cable source for cable and the combo source to tape from your VHS/dvd combo. Its a pain but you have to select Source everytime you turn the Ilo back on. You could hook your Cable to the ILO but would have to turn on ILO everytime to watch tv. Two remotes is a chore but you have to use tv remote for the volume anyway so it doesn't matter. Hope this helps.
Mar 30, 2008 | iLO DVDR05 DVD Recorder
Operating unit
This unit will not record certain types of TV and no copy-protected VHS and it doesn't tell you when you have those situations--and it doesn't come up with an error message that tells you what you are doing wrong. First step is to be sure that your source material is not copy-protected.
Jan 04, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Connecting new dvd/vhs combo player recorder.
When you had the old combo hooked up the tv was on channel 3 now you have hooked up to s cable or component, you have to switch the tv input to the input you are pluged into using the tv remote
Dec 27, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
