Question about Heavyduty Jazzy 1121 Standard & Heavy Duty Power Wheelchair
Can the speed of the Jazzy Power chair be increased beyond the setting on the armrest remote controller?
    Novelist:
    Champion:
  • 232 Answers
Make sure that your tires are properly inflated and that you are not carrying more weight than the power chair will allow and that your batteries are fully charged.
If you got your chair second hand, sometimes the previous owner has the technician change the controller settings to "dampen" it to slow it down to allow them greater response time and control. The technician can reprogram the controller to take it back to 100%. If you got the power chair new, it should be at 100% already.
Take it easy, HotRod. It's a medical device, not a car!
Posted on Oct 20, 2010
What batteries do I need for a jazzy select6 pride
information and batteries for sale.
info
Jazzy Select 6 - Specifications, Owner's Manual, Features & Benefits
www.pridemobility.com > Jazzy Power Chairs > Models
  1. Cached
  2. Similar
In-line motor technology for increased efficiency, torque and range. Built with ease of service in mind. Easy side access batteries. Tool-less front panel access to ...
[PDF]Jazzy Select Series - Pride Mobility
www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_select_series_om.pdf
  1. Cached
  2. Similar
6 www.pridemobility.com. Jazzy Select Series. II. SAFETY. Do not connect an extension cord to the AC/DC converter or the battery charger. Removal of ... Batteries for Sale
Pride Mobility Jazzy Select 6 Ultra Wheelchair and Mobility Batteries at ...
https://www.batteriesplus.com > Batteries > Wheelchair and Mobility > Pride Mobility
  1. Cached
  2. Similar
If you rely on a Pride Mobility Jazzy Select 6 Ultra powered wheelchair or personal mobility scooter to get around, Batteries Plus Bulbs can help you find the ...
Pride Jazzy Select 6 Power Chair from Pride Mobility ' 1800wheelchair ...
www.1800wheelchair.ca > Brand Showcase > Pride Mobility > Pride Powerchairs
  1. Cached
The Jazzy Select 6 Power Wheelchair from Pride Mobility is the ultimate ... Easy side access batteries; Full-length, flip-up armrests; Solid flat-free tires; Foot ...
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca ...
https://www.amazon.ca/Jazzy-Select-Scooter-Battery-Charger/dp/B00CIZ1GW6
  1. Cached
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca: Sports & Outdoors.
Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery
https://www.amazon.com/Mobility-Jazzy-Select-Wheelchair-Battery/dp/B009DKGCC8
  1. Cached
Rating: 5 - ‎1 review Buy Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery - This is an AJC Brand® Replacement on Amazon.com ? FREE SHIPPING on qualified orders.
ALL THE INFO HERE BELOW
Google
Nov 24, 2016 | Pride Health & Beauty
Previous owner had to have speed adjusted all the way down on my pride mobility jazzy 1103 ultra chair. How do i turn the speed back up
You would need a hand held programmer to adjust the controller settings. The least expensive route short of purchasing a programmer is to bring the power chair into a local dealer to get it programmed. Hope this helps.
Apr 04, 2016 | Pride Health & Beauty
How do you increase the speed in Jet3 power chair
I take it you are talking about increasing the maximum speed beyond the maximum the chair is set for now! the max listed speed for the jet 3 is 4mps, so if your chair is doing that there is only changing a load of hardware to increase speed past that (it is very costly) if your chair is second hand it may be that the chairs programming has been changed to reduce the max speed say for in-door use or for elderly with slow reactions to better control the chair, if that is the case it depends on the controller you have it would need a programmer box, you can buy these on ebay and the like or you could take it to a mobility shop and see if they will change it, a lot of these shops will offer to do it free to try and get your future custom, it only takes a couple of mins, most will just plug in to the charge / data port on the controller, select from the menu and adjust the speed etc. hope that helps.
Jul 09, 2014 | Jet 3 Ultra Power Chair
All the lights are blinking on the speed display.. we've had the chair plugged into both the back of the chair and the armrest.. the chair still won't move.
The speed display will flash whenever you have the charger plugged in. Either in the back or in the joystick. Hopefully you didn't have them both plugged in at the same time. If after you unplug the charger you still get the flashing speed lights then you have an inhibit problem with the chair. The inhibit function will keep you from being able to drive the chair while charging. This repair is beyond anything you can do and must be referred to a Pride dealer or Repair service Hope this helps you
Apr 22, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Is the horn on my jazzy power chair 12 or 24 volt? the horn is so weak that you can barely hear it and i would like to replace it with a roadrunner beep beep horn, but it is 12 volt. and the system on my...
Bob why don't you run a small 2 wire cable from one battery to the armrest where your joystick is located and attach the new horn and a small push button switch to the joystick bracket coming from under the armrest. loosen the knob tightening the joystick bar and pull it out enough for you to attach the horn and button to it. I 'm not sure if that will work because I don't know what the new horn looks like but you can also mount the horn under the shroud near the battery and run the wire to the switch at the joystick. Good luck sounds like an good project
Feb 27, 2011 | Pride Jazzy 1103 Ultra Standard Power...
How do you dial up the speed on the jazzy select 6
jrw if you are asking to increase the programmed speed of the chair then you need a programmer (a PP1) that will allow uo to increase the factory speed. But it's probably set at 100% already. Other than setting the speed on the joystick to full and changing the programmed speed will you be able to get the chair 's speed increased Hope this helps you
Oct 17, 2010 | Pride Jazzy Select 6 Indoor Power...
Is there a way to increase the width of the armrests? My paraplegic pt is getting pressure areas on the side of his L thigh because it leans against the armrest. thanks!
Behind the chair where the armrests go into the frame are two knobs loosen these knobs and you can adjust (pull out) the armrests to the size you need then retighten the knobs to keep them in place
Aug 04, 2010 | Jet 3 Ultra Power Chair
My father has a jazzy select power chair. The spe...
You will have to take it to a mobility dealer to have it programmed
May 14, 2010 | Health & Beauty
MY CHAIR WILL NOT CHANGE SPEEDS IT IS VERY SLOW AND WILL NOT INCREASE SPEED AT ALL. LIGHTS ON POWER LIGHT INDICATOR FLASHES CONTINUOULSLY
Your batteries are bad or not charged up is it only 1 red light flashing or is it all power lights flashing 1 red means not enough charge. all means internal problem with joy stick
Mar 05, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Chair runs to fast in high speed. can it be slowed down
If you can alter the speed, there will be a dial on the armrests to turn it down, i presume you have 4mph and 8mph,the dial will adjust the speed , so that it takes longer to reach 8mph.
Sep 25, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Heavyduty Jazzy 1121 Standard & Heavy Duty Power Wheelchair Logo
261 people viewed this question
Top Heavyduty Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Heavyduty Health and Beauty Expert? Answer questions, earn points and help others
