Question about GE Spacemaker JVM1640SJ Microwave Oven
GE over the range space saver microwave
The thing just came on by itself. My husband and I were in the dining room and heard the thing come on. The time/scroll area said sensor error. now what do I do?
  • GE Master
  • 9,086 Answers
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Posted on Apr 23, 2008
Replace mounting nuts on a GE undercabinet microwave
Depending upon where inside the microwave the nut dropped, it may be necessary to open the cabinet to retrieve it.
Jan 01, 2014 | GE JVM1440 Microwave Oven
Our Spacemaker microwave intermittently shuts off after running 2 seconds, and will not run properly even when unplugged and then plugged back in. Later in the day, it might work fine. What is the likely...
For crazy it may sound humidity could be affecting your unit. Its known the way microwaves work is exciting the water molecules, this creates vapor that will condense in cooler surfaces...well if that happens to be the electronic controls boards or other sensitive components your unit may react doing unexpected things. If it is an space saver oven on top of a range getting all the vapors from whatever is boiling, that adds to it. Also check your unit is connected to a verified grounded outlet. This is critical for the operation and for the longevity of your appliance.
Dec 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
When microwave is turned on the light in the kitchen gets really bright, but the light in the dining room goes dime, and also have a fan in dining room area plugged in recept and it slow down almost to a...
Main power ground some where between the outside line and the meter.
Have a electrician to check for you if you are not familiar with millimeter and electricity. Danger !!!!
Not all electrician are smart. Some might ask you to replace this and that...?
Good luck
Mai Lor
May 11, 2017 | Samsung MW5351G Microwave Oven
GE JVM130K004 space saver microwave not working
The magnetron is overheating, and the magnetron thermostat is tripping, interrupting power until it cools back down.
This is to protect the magnetron from being destroyed from overheating.
It may be that the internal cooling is not occurring or the magnetron is failing. Cooling can be compromised by:
- failed or failing internal cooling fan
- blocked air inlet or filter
- outer cover not installed correctly
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Feb 09, 2010 | GE Microwave Ovens
GE space saver Microwave not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge Microwave space saver over range working but
It is a good possibility that the stirrer has failed. In the top of cabinet is a round cover,there is a small round plug in the edge of it,pry plug out and put it in safe place,rotate the cover < twist locks > gently let it down and stirrer will be either setting on cover or still attached. If you notice any damage< it is a round aluminum disc that is flat > then you need a new one. If you don't see any damage put it back in < put in hole and turn until you feel it line up with shaft and push into place,< gently >.Make note of position and put cover back on < stirrer does not lock on shaft so you have to hold it up until you get cover under it in most cases. Run a short cycle and remove cover to see if it turned at all. If not the motor is bad < turns stirrer during operation>. This is the first time that question has been asked of me and it is the only thing that I can think of if it heats glass and not food.
Apr 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Reset shows on display of my GE space saver microwave oven
change the board that has the reset on the display board it is bad
Mar 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Code on the space between oven and microwave
It's normally about 30", but that info will be in either the installation manual or the owner's manual, depending on the brand you choose.
You mention SpaceSaver, that's GE.
You can download GE owner's manuals and installation instructions here.
Feb 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Not heating properly
I have a GE over the range space saver microwave that was only 18 mos. old when it stopped heating. GE replaced the magnetron for us at no charge but since we did not have a service contract - they charged us $200 to install it. It only cost $375 new installed. Your choice.
Nov 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
147 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
