Question about Maytag MER6772 Gemini Electric Kitchen Range
F1-1 on the range screen shows F1-1 we tried everything to unplug it and plug it back didn't work.please help with solusion.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code F1-1 in your Maytag Gemini Indicates runaway cook in upper oven and to resolve this issue you’ll have to check the oven temperature sensor & replace if it has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 03, 2010
Fridgidaire self cleaning range: F1 error code?
You have a control board failure. First thing I would try is to unplug the range for at least 10 min. and then plug back in and see if that works. Hope that helps
May 29, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Model sve47100 range - display shows f1 and nothing on oven works
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing. 2. Gain access inside the control panel. 3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC. 4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was. 5. Turn the power back on. 6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping) 7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Nov 15, 2011 | Jenn-Air Kitchen Ranges
Frigidaire stove(smooth top -electric) all of sudden started to beep' constantly w/F1 flashing.Tried to reset - unsuccessful. Unplugged & waited an hour to plug back in & still beeping...
The F1 error code means a button on the touchpad is stuck,usually pushing clear/off will clear it. Since you have done that and it returns the touchpad needs to be replaced
Gene
Aug 11, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
F1 flashes after unit has been plugged in for awhile. It works, but we have to unplug it to get rid of beep and F1 message. Any ideas?
You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part.
If you dotn find this new part in your store, check THIS LINK to repair service.
Hops helps.
Apr 18, 2011 | Kenmore 95042 / 95044 Electric Kitchen...
I have a Kenmore Ceran electric slide in range, model # 629.46799895 ...it was on, started beeping, and showing fault code F1 on the screen
Sorry to read about your problem.
Try this to determine which part is needed.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
I tried to help you.Please help ma and rate/vote this responce. Thanks and good luck
Jan 04, 2011 | Kenmore Kitchen Ranges
Magic Chef Oven 3888VRA beeps and shows F-1.
Hi this is indicating a Defective touch pad or clock (ERC).
This simple test will help determine whether the ERC (Electronic Range Control board or Clock) or the touch pad is defective when F1 error code is present. Follow carefully, and with caution.
Warning: Do not preform this test if you feel as if you are not qualified to do so. Contact your local service depot, if needed.
Nov 17, 2009 | Magic Chef CER3725AA Electric Kitchen...
Maytag electric range shows F1 error message and beeps every hour or so. we've checked the fuses and they seem okay.
F1 code means a defective touchpad or membrane, usually the touch pad. Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1: Disconnect the power to the range
Gain access to the back of the ERC (clock)
Unplug the touchpad ribbon connector from the clock
Make sure everything is clear & will not short out when the power is turned back on to the range. Replace any covers removed to gain access to the ERC.
Turn the power back on to the range
Watch for the F1 and listen for the beepIf you get the F1 and beep, replace the ERC (clock)
If after approx. 60 min. you do not get the F1 fault, replace the touch pad. Note: some ranges incorporate the touchpad and the clock as one part so F1 means a bad clock control.
Nov 12, 2009 | Maytag MER5770 Electric Kitchen Range
Oven turns on by itself and F1 flashes on the digital clock
Without being able to look up the error codes for your model (number please!), I would guess that the oven control triac has shorted out or the relay is stuck on (I assume the oven runs at maximum temperature). In any case, the oven microcontroller knows something is wrong, so it says F1 and beeps for help.
Aug 10, 2009 | Kenmore Kitchen Ranges
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
MER5730AGW Electric Range
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Aug 14, 2007 | Maytag MER5775Q Electric Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
167 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
