Question about Panasonic DMC-ZS1 Digital Camera
How to remove thumbnail displayed on my panasonic dmc-zs1 screen
SOURCE: Lumix DMC ZS1 w/4gb card not recognized
Called Panasonic's Tech Support and talked to a real person (!) on Thanksgiving Day(!). She suggested not disconnecting or turning off the system, as it might damage the SD card. Instead we concluded it would be best to leave the camera alone, and allow the battery to run down. I did, then removed the card. Bought a (Sony) card reader next day, and it works great. Just copied the disk directly from reader to computer, ignoring the Panasonic software.
Posted on Nov 29, 2009
  • 11967 Answers
SOURCE: Panasonic lumix DMC-ZS1 - won't record video
It might be telling you that the card you have in the camera isn't fast enough to keep up with the demands of a video recording. You need to buy a more expensive card with a faster speed rating.
Posted on Jan 19, 2010
  • 668 Answers
SOURCE: broken screen on panasonic lumix dmc-fx9. Is it
It is not worth fixing it because it will cost you alot . The cost of repairing screen will be around $70-100.
Posted on Jan 27, 2010
tbreeze47
  • 3083 Answers
SOURCE: I own a Lumix Panasonic
If you put the camera on "manual focus", the pics would probably be fuzzy. Go into your menu to the focus option and set it back on automatic. Some cameras have a shortcut to it, and that's probably what you did. Refer to your manual, and you will learn how to turn it on and off...manual focus is nice in certain conditions.
If it's not your settings, your focus ring inside the lens assembly could be stuck. Try spraying it out with compressed air, or bumping the camera gently with your palm to try to free it up.
Good luck, hope it's just a setting.
Posted on Sep 11, 2010
lock123
  • 6831 Answers
SOURCE: My panasonic lumix DMC-ZS1 has "Zoom Error". How
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
My DMC-Z51 will only write to internal memory and not to sd chip
You need to get rid of the pics on the internal memory. With no card in the camera, go into the menu and find "format"....follow the on-screen instructions to erase the internal memory. After that, your memory card should work.
Oct 01, 2011 | Panasonic DMC-ZS1 Digital Camera
In playback/review mode of photos, only some appear while others are blank. All photos are present when uploaded to the computer or displayed at a photo kiosk, but only intermittent photos can be reviewed...
If, after viewing the pics on a computer, you don't use the "safely remove hardware" function before pulling out the cord/card, the files on the card may become corrupted and not recognized by the camera anymore.
Jul 12, 2010 | Panasonic DMC-ZS1 Digital Camera
I have a Panasonic Lumix DMC-ZS1. Once I transfer the media cards pictures onto the computer and then re-insert the card into the camera, all pictures seem to have been deleted. However, when I take the...
When you remove the card from the computer, do you use the "safely remove hardware" function? If you don't, the card can become corrupted enough that your camera no longer recognizes it.
Apr 26, 2010 | Panasonic DMC-ZS1 Digital Camera
Why windows movie maker is not capturing movies from dmc-zs1?
Try downloading them to a folder you create on your desktop first.
Mar 24, 2010 | Panasonic DMC-ZS1 Digital Camera
Jan 19, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic lumix Fz28, Error "Thumbnail is displayed"
I have this problem too, but only when I try to view pictures I have taken on a later model. Photos taken with the FZ28 view as per normal.
Jun 14, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Panasonic DMC-ZS1 Digital Camera Logo
93 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
