Question about Panasonic DMC-TZ4 Digital Camera
How to remove the thumbnail displayed on my dmc-zs1 panasonic
SOURCE: Lumix DMC ZS1 w/4gb card not recognized
Called Panasonic's Tech Support and talked to a real person (!) on Thanksgiving Day(!). She suggested not disconnecting or turning off the system, as it might damage the SD card. Instead we concluded it would be best to leave the camera alone, and allow the battery to run down. I did, then removed the card. Bought a (Sony) card reader next day, and it works great. Just copied the disk directly from reader to computer, ignoring the Panasonic software.
Posted on Nov 29, 2009
  • 11967 Answers
SOURCE: Panasonic lumix DMC-ZS1 - won't record video
It might be telling you that the card you have in the camera isn't fast enough to keep up with the demands of a video recording. You need to buy a more expensive card with a faster speed rating.
Posted on Jan 19, 2010
tbreeze47
  • 3083 Answers
SOURCE: I own a Lumix Panasonic
If you put the camera on "manual focus", the pics would probably be fuzzy. Go into your menu to the focus option and set it back on automatic. Some cameras have a shortcut to it, and that's probably what you did. Refer to your manual, and you will learn how to turn it on and off...manual focus is nice in certain conditions.
If it's not your settings, your focus ring inside the lens assembly could be stuck. Try spraying it out with compressed air, or bumping the camera gently with your palm to try to free it up.
Good luck, hope it's just a setting.
Posted on Sep 11, 2010
lock123
  • 6831 Answers
SOURCE: My panasonic lumix DMC-ZS1 has "Zoom Error". How
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
  • 11967 Answers
SOURCE: i have a lumix panasonic dmc-zs1 camera and the
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 17, 2011
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
My camera(panasonic dmc-zs1) has apparently been damaged by static electricity. I did feel a static shock when i went to pick it up. It will turn on and off but will not respond to any of the buttons...
When electronic hardware take a static shock it scrambles the processor and locks most functions down. One possible solution is to remove the battery and the memory card and allow 30 minutes to get rid of any residual charge and allow the processor to reset. Replace the battery only at this point, now try your camera to see if it will operate, if all goes well load the card back in, if this fails it is more practical to replace the camera and cheaper in the long run.
Jan 28, 2011 | Panasonic DMC-ZS1 Digital Camera
In playback/review mode of photos, only some appear while others are blank. All photos are present when uploaded to the computer or displayed at a photo kiosk, but only intermittent photos can be reviewed...
If, after viewing the pics on a computer, you don't use the "safely remove hardware" function before pulling out the cord/card, the files on the card may become corrupted and not recognized by the camera anymore.
Jul 12, 2010 | Panasonic DMC-ZS1 Digital Camera
I have a Panasonic Lumix DMC-ZS1. Once I transfer the media cards pictures onto the computer and then re-insert the card into the camera, all pictures seem to have been deleted. However, when I take the...
When you remove the card from the computer, do you use the "safely remove hardware" function? If you don't, the card can become corrupted enough that your camera no longer recognizes it.
Apr 26, 2010 | Panasonic DMC-ZS1 Digital Camera
Why windows movie maker is not capturing movies from dmc-zs1?
Try downloading them to a folder you create on your desktop first.
Mar 24, 2010 | Panasonic DMC-ZS1 Digital Camera
Jan 19, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic lumix Fz28, Error "Thumbnail is displayed"
I have this problem too, but only when I try to view pictures I have taken on a later model. Photos taken with the FZ28 view as per normal.
Jun 14, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Panasonic DMC-TZ4 Digital Camera Logo
325 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
