Question about Gateway MX3702 Notebook
My sound tool at the bottom right hand of the computer has a red x on it and it says No audio device is installed and i have tried several things downloading other drivers restarting the computer many times but nothing. This whole thing started when I got windows xp upgraded to windows vista can you help me Please
  • 10,421 Answers
Audio
Try to update the latest audio driver for audio device in your notebook
Jan 07, 2013 | Toshiba Tecra A6-EZ6311 Notebook
I can not install sound ,i have error code40
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers
click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select
playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although
once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
hope it helps
Sep 25, 2012 | Dell OptiPlex GX620n PC Desktop
No sound, drivers can't be found
right click on the red X icon select playback devices there will be a red x on the speakers right click configure them
hope this helps
Jun 27, 2012 | Gateway Computers & Internet
The sound on my computer says it has been disabled or "no audio detected". My speaker icon on the task bar has a consistent red "x" beside it. I obviously have no audio output, whether...
the red x in the bottom toolbar means the drivers have been corrupted and need reinstalling
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if you dont have a motherboard disc you will have to download the drivers
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download them
Sep 06, 2011 | HP (153147-001) Sound Card
I dont have sound in my ibm thinkpad T.43 centrino
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver or
scroll to sytem speaker right click select properties you will see at the bottom use this device enable/disable this device
hope this helps
Dec 19, 2010 | Computers & Internet
Why there is no sound in my pc?
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver or scroll to sytem speaker right click select properties you will see at the bottom use this device enable/disable this device
hope this helps
Nov 26, 2010 | Computers & Internet
There is a sound problem. i installed window xp recently , after that i installed drivers everything is done but sound driver is not performing so please tell me solution right now
hope this helps
Nov 26, 2010 | AMD Sempron 2800+, 1.6 GHz (G54222)
I am not able to get any sound from my speakers. Technician said that my sound card is fine
hope this helps
Nov 10, 2010 | Harman Kardon HK19.5 Computer Speakers
Computer dont recognizing audio device (no sound device?) after installation of windows 7. a tried to deinstall and reinstal realtek hd audio drivers, and its still the same??
hope this helps
Nov 10, 2010 | ASUS M2N68-AM SE2 Motherboard
No audio output device installed
Where are you checking? In the Device Manager?
Go there and disable the sound device and then reboot and enable it again. (If you get there and see a device disabled, just enable it and check again to see if you have sound).
Try this and report back if you still have problems.
Please be aware that Microsoft has an excellent online troubleshooter for Vista available here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 02, 2009 | Microsoft Windows Vista Home Premium with...
Gateway MX3702 Notebook Logo
76 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
