Question about Panasonic KX-P2023 Matrix Printer
Kx-p2023 vibration This printer just started making noise and vibrating for about 5 seconds, then all lights light up and it won't print. Please help. Thanks. Paul
  • Panasonic Master
  • 5,568 Answers
You probably have a power supply problem and searching for the failed part requires some knowledge and a couple pieces of test equipment.
The vibration is liekly caused because a DC voltage produced inside has AC ripple on it because of a failed part, probably a bad capacitor.
Posted on Jun 23, 2008
How do you get Panasonic KX-P2023 to print 8.5" x 7" tractor feed using Windows 7?
for 32 bit
Use EPSON
LQ Series 1(80)
INBOX Driver*
1 INBOX Driver is Printer Driver that is included in Windows 7.
Mar 18, 2010 | Panasonic KX-P2023 Matrix Printer
P2023 prints garbage with vista
Did you get the Vista driver for your machine from Panasonic? If not, it may not work. I use VM ware and run windows xp in virtual machine in order to use some of the older drivers.
Jul 30, 2009 | Panasonic KX-P2023 Matrix Printer
I am printing individual labels and want the stop after printing the label - goes down 4 or 5 labels
You have to go into your printer settings and change the size of the "paper" you are printing to so that it matches the size of the labels you are printing to.
Jul 15, 2009 | Panasonic KX-P2023 Matrix Printer
Prints one line per page
check your printer settings. go to preview print page before printing. Might have to uninstall printer and reinstall it again. Hope that helps You.
May 24, 2009 | Panasonic KX-P2023 Matrix Printer
Won't print dark black; prints in gray
There are a few possible causes for the light print.
The first is the easiest to try and least expensive.
If you actually had a bad toner cartridge, and the toner was not making its way down the toner tube to the developer, then you may be able to fix the issue by simply doing a developer cleaning on the black developer. What this actually does is force aggitator to move toner down the tube into the developer. You can activate this from the maintenance menu.
If this does not fix the issue, then more then likely the black developer unit itself is defective and needs to be replaced.
Nov 07, 2008 | Dell 5100cn Laser Printer
Printer WILL NOT LOAD or ADVANCE PAPER
I have the same problem with my epson CX3810. Paper won't load or advance. Any solutions???
Feb 13, 2008 | Panasonic KX-P2023 24-Pin Impact Printer
hai
apply some oil to the rod . keep the head postion in the last. Try to print with out the ribbon catriage
thank u
Feb 04, 2008 | Panasonic KX-P2023 Matrix Printer
I NEED TO GET A DISK SO I CAN ADD TO MY COMPUTER. PANASONIC KX-P2023
If your looking for the printer driver, it should already be in the computer. Windows 2000, XP and Vista all come with the KX-P2023 driver pre-loaded. If you can't find it, you can use just about any of the KX-P2000 series drivers that are pre-loaded wqith Windows.
Oct 15, 2007 | Panasonic KX-P2023 24-Pin Impact Printer
Panasonic KX-P2023 Matrix Printer Logo
55 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
