The underwire from my wifes bra has gone through a hole in the drum in our washer. its stuck itself under the drum and is making an awful noise. do u think it would be possible for me to remove myself? if so, how? its a hoover nextra ultima and its less than 12 months old if that helps. Please help!!
  • 487 Answers
When you do this the waranty will be voided.
it is not too hard to remove but it is time consuming. Did this many times before but you have to be patient and methodical.
not what you take of and you will have to split the outer drum.
Posted on Apr 21, 2008
Maytag Nuptune washer in spin cycle sounds like a plane taking off
Something small, like a paperclip or the wire from an underwire bra can get stuck in the holes in the drum, and rub against the outer drum. You will have to check carefully to find it.
Mar 16, 2012 | Maytag Neptune MAH5500B Front Load Washer
During the spin the washer makes much more noise than it has in the past. There are also small chunks of hard plastic showing up in the clothes.
There may be an object that has gone through one of the holes of the spin basket, check to see, something like a bra underwire may have gone through and is rubbing on the inside of the tub
Aug 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer makes a click noise 2 times per rotation on the spin cycle. Even when empty, when i turn it the same noise happens.
typically a bra wire under the drum will cause this noise. a faulty motor will do it but with 10x more clicks . so look for rogue underwire.
Nov 09, 2010 | Washing Machines
Washer is putting holes in clothes
Check the inside of the drum when the machine is empty by feeling the entire surface with your hand. Take care as you are looking for something that's got stuck in one of the holes in the drum and is protruding into the drum, and this can often be a wire from an underwired bra!
If you find anything it should be removed by pulling it out carefull with a pair of pliers.
Mar 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Grinding while tub is turning
There is probably something stuck in the drom or the drum seal. I would check for the underwire from a bra this is a commmon problem the wire comes out and gets stuck in holes in the drum.
Mar 04, 2010 | Maytag NFW7200TW Front Load Washer
BRA UNDERWIRE STUCK IN DRUM
not posative but there should be a panel at the back that should come off to get at the drum
Aug 27, 2009 | Candy CN146 Front Load Washer
Bra underwire stuck
disconnect from electricity. take back panel off.you will see heater at bottom of tub held in by 1 10mm nut.disconnect wires to it. loosen this nut and pull heater out - you may have to help it with a screwdriver. you can then see into the gap between tub and drum and fish for the bra wire.
tell her not to wear bras with wires!!
Jul 14, 2008 | Electrolux EW1000i Front Load Washer
Bra wire stuck
you may not have to take the washer apart, take a good ligtht and look around inside the spin tub, if a part of the underwire is sticking thru, try and pull it out. Do not use the washer until the wire is removed or it actually could cut the tub and then the machine will leak $$$
Let me know the make and model if you need more assistance
T
May 22, 2008 | Washing Machines
Lost a underwire from a bra
Bra underwires are one of the main engines of the appliance repair buisness.
You do need to keep a close eye out for it in the filter but it probably will do no good to call for repair. The repairman most likely will check the filter and tell you to call back if you have any trouble. Until it works it's way down there isn't much you can do without disassembling the washer.(no small feat for some of them) The only real damage that may occur is if it pokes a hole in the drain hose between the tub and pump. This has happened, but rarely. They will usually make their way to the pump and you will hear the noise, at which time you can usually remove it with no trouble.
Be sure to wash bras in a delicates bag on delicate cycle in the future.
Hope this helps.
Thanks/Mike
Nov 06, 2007 | Washing Machines
Bra underwire stuck
Switch off machine and unplug it from the wall socket. Remove back plate and identify the heating element. It should be located at the bottom of the outer drum. Remove element and you will have limited access to the space between the drums. Rotate the drum slowly by hand untill the bra wire gets to the bottom of the drum. Remove obstruction with hook or long tweeser.
Oct 31, 2007 | Bosch WFMC6401UC
Washing Machines Logo
248 people viewed this question
Top Washing Machines Experts
