Sherwood RV-1340R won't power up when you press the power button. The standby light is on until you press power and then there are no lights on at all. Everything is also connected correcly as i have been using this amp for quite some time now. Could it be the main fuse at the back possibly?
sree-here
  • 61 Answers
SOURCE: Sherwood rv 6030r does not turn on.
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If the remote is OK, then the problem with the Remote Sensor or related components of the receiver.
Posted on Mar 11, 2009
jomabug76
  • 1148 Answers
SOURCE: Sherwood RV-8070R, i can t switch it on
TRY BLOWING IT OUT WITH A AIR COMPRESSER
Posted on May 15, 2009
Grubhead
  • 5554 Answers
SOURCE: Sherwood model RV 5050r - tuner is not holding
Try looking for one of these Memory Retention Capacitors, they cause a lot of trouble like that. It will be in the tuner section somewhere if it uses one. It could look a bit different to this one, so bare that in mind.
Posted on Mar 06, 2010
dunnbiker
  • 8546 Answers
SOURCE: Sherwood RV-4050R compatible with new gear?
The TV is irrelevant.
BD would need HDMI, digital audio or 5.1 analog inputs on the contol receiver. You have none of these.
Posted on Jun 21, 2010
jdvillanueva
  • 2098 Answers
SOURCE: The problem I ran into
Hi amit2817,
Your unit gone to overload that caused the subsequent shutdown. To isolate the input and speakers from fault, disconnect all input cables and speaker wire from the unit then turn it on naked. If the symptom still there then this is a clear indication that the fault came from the unit itself. Most common caused of this problem is the sound output circuitry and the power supply. Most common affected parts in the output section is the output IC/transistor(mounted in the large heat sink). It will fail because of exposure to excessive heat due to frequent high volume and or because of aging. Bad solder joints is also to consider to this section and also to the power supply section. Because of heat build up, most of the joints dried resulting to poor flow of the supply and trigger the over current(overload) protection circuit. Leaky electrolytic filter capacitor is also one of the factor in this fault. It will produce an out-of-regulation to the power supply output. You must have a capacitor checker to determine its condition. Sometimes it has a bulged/dome at the top but not all.
If you don't have necessary tools and test instrument and can't troubleshoot the symptom, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 02, 2011
Sherwood rv 5030r
Sounds like it is going into protect. This is usually caused by a problem in the amplifier section. I would start by making sure none of the output transistors are shorted.
Jul 08, 2013 | Audio Players & Recorders
Sherwood RX-4105 Amp won't power on.
HI,
You will have to check the fuse.There probably is a fuse next to where the power cord goes into it. It will look like a little round black cap. It may be necessary to push on it and twist it in order to get it out. It will be marked on the case with a number followed by the letter "A", that being the fuse rating in amperes.
Sep 30, 2008 | Sherwood RX-4105 Receiver
Sherwood
does a code pop up like f20 or just any code
Mar 20, 2013 | Audio Players & Recorders
RC-3910 Toshiba television won't turn on, has flashing standby light?
Missing power supply rails from the main power regulator board to sub boards is the fault. Contact any experienced service technician to get this set repaired, since the work is skilled one.
Jul 11, 2012 | Toshiba Televison & Video
My dish network remote control will not control a sherwood rx-4109 am/fm stere rec.
Try these codes: 670,646 The steps for programming these remotes are below:
1.) Hold down the aux button until all four mode buttons are lit.
2.) Enter the three digit code and press pound (#)
If those codes fail try the steps below they are for what is called a Power Scan. This should resolve this unless there is a compatibility issue.
1.) With the desired equipment on, press and hold the correct AUX button until all mode button backlights illuminate (about 3 seconds), then release.
2.) press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
3.) Press and release the large red Power button.
4.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
To verify the code works try several different functions for that equipment.
Daniel Busa
DISH Network Customer Service
Feb 22, 2011 | Sherwood RX-4109
May 13, 2009 | Sherwood RX-4109
Lexicon RV-8 wakupe failure
Did you try this....
In the event of a power outage, the RV-8 will display a BROWN
OUT!! PRESS STANDBY message. To turn the unit on, use the
STANDBY button. For more information, see “POWER
MANAGEMENT” on page 3-3....
POWER MANAGEMENT ON, OFF
"Setup" >> "Power Management"
Opens the POWER MANAGEMENT menu, which is used to automatically
put the RV-8 into standby mode during brownouts.
When set to ON, the RV-8 detects low voltage levels or a momentary
loss of power and puts the device in standby mode. In the event of a
power brown out, the RV-8 will display a BROWN OUT!! PRESS
STANDBY message. To turn the unit back on, use the front panel
STANDYBY button.
When set to OFF, the RV-8 will attempt to function during a
momentary power loss, however software settings may become
corrupt and need to be reset.
When the RV-8 is in standby mode, pressing the button turns the
unit on and activates all zones that were active in the previous
operating session.
The RV-8 does not power on.
1. Make sure the rear-panel power switch is set to the | (“on”)
position.
2. Attempt to power on the RV-8 with the front-panel Standby
button and remote control On button.
3. Examine the power cord to ensure a good connection between
the rear-panel AC input connector and the wall outlet.
4. Check the electrical circuit and breaker.
Apr 05, 2009 | Lexicon RV-8 V2.0 Amplifier
System lights up when plugged in but stays in stand-by mode
if it is wet please remoove the cover and dry it by using hair dryer .after that still the same it can be bad solder joints.
can you resolder the printed circuit board.
nuwan....
Jan 12, 2009 | Sherwood RD-6500 Receiver
Dec 25, 2008 | Sherwood R-945 Receiver
No High Voltage
I did solve the problem with the Sherwood receiver R6036-R
The problem was a broken solder Trace towards the power cord on the powersupply board.
Thanks for your concern
May 30, 2008 | Sherwood RVD-6095R Receiver
171 people viewed this question
 Grubhead
Grubhead
