Question about Delphi SKYFi3 XM Radio Receiver
Power is plugged in unit will not turn on - Delphi SKYFi3 XM Radio Receiver
  • 17,130 Answers
This can be a volley of faults. First disconnect the set and using a good multimeter check the continuity from the plug to the mains switch. next check the fuse, if blown check for surge protector short, mains transformer , the dc rectifier, mains capacitor. Check for mains / sub votages. If present then you will need more expertise to check in for failue of active electonics components. If not you are lucky to find the fault within this area. Helpful? Good day
Posted on Jul 20, 2010
Lumio light
Regarding your question you could try a power discharge for your device:
- disconnect the AC adapter
- unplug the battery (if detachable)
- press and hold down the power button for 30 seconds (to discharge the components)
- plug the AC adapter only (without the battery if it is detachable)
- turn on the unit
If the battery is not detachable, please follow the procedure with the battery attatched.
- turn off the unit
- turn on the unit
Dec 15, 2015 | Computers & Internet
The green light is on the power plug but i get no power on the machine, no lights no air nothing
Press the reset button on the power plug and wait 3 minutes before restarting the unit.If that fails to work. Turn the ON/OFF Switch on the unit to OFF & unplug the unit for 15 minutes. Then plug the unit back in, turn the ON/OFF Switch to ON. During that 15 minute time out, the unit should have reverted back to it's original factory settings. From there you can adjust the settings as you like.
Hope this helped you and thanks for choosing FixYa.
Jul 29, 2011 | Royal Sovereign ARP9009TL Air Conditioner
My printer is showing error oxdo5do1od recycle power how can i over come that
Please perform the following steps:
Step 1: Power Cycle
1. “Shutdown” your computer.
2. Verify that the unit is switched ‘on’.Unplug the all-in-one from power and ‘disconnect’ the connection port.
3. Wait 30 seconds.
4. Plug-in only the ‘power cord’.
5. Repeat steps 2-4 two more times.
6. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
7. Restart your computer and check the functionality.
Step 2: Partial reset:
1. Unplug the power cord from the unit.
2. Press and hold # and 3 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit
If the issue persists, perform the following:
Step 3: Semi ful reset:
2. Press and hold # and 6 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit.
If the issue persists, pleae conect the unit to a diffrent power out let. Also please chek if the unit works fine in the stand alone mode (with out connecting to the computer). If the issue persists, replace the printer
:) Dr Tony
Apr 19, 2010 | HP Officejet 5610 All-In-One InkJet...
Has power but nothing comes on Mod. ACE 184 X SO Whirlpool
TURN OFF THE BREAKER AND UNPLUG THE UNIT FROM THE OUTLET...WAIT 2 OR 3 MIN. AND TURN BREAKER BACK ON AND
PLUG THE UNIT BACK IN AND TURN THE POWER ON....IF THE
SAME RESULT AS BEFORE...REPEAT ALL STEPS EXCEPT PLUG THE UNIT IN A DIFFERENT OUTLET...IF THE PROBLEM PERSISTS , UNPLUG THE UNIT AND MAKE SURE THE POWER CORD IS SECURELY FASTENED INSIDE OF THE UNIT AND CHECK FOR ANY BURNT OR LOOSE WIRES OR FUSES OR GROUNDS.
Apr 03, 2010 | Heating & Cooling
The fax log will not load when prompted
Please perform the resets given below and check if you are able to print the fax log. Please perform all the resets.
*** Partial Reset ***
* Turn on the unit
* Disconnect the power cord from the back of the unit
* Press # and 3 buttons simultaneously while plugging the power cord to the unit.
*** Semifull Reset ***
* Turn on the unit
* Press # and 6 buttons simultaneously while plugging the power cord to the unit.
*** NVM Reset ***
* Turn on the unit
* Press OK and Cancel buttons simultaneously while plugging the power cord to the unit.
Wish
Jul 31, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Readout screen says can't scan or fax,turn off and try again,
Please follow the steps given below and check the functionality.
Bypass the surge protector
If the all-in-one is plugged into a power strip, remove it from the power strip and plug it directly into a wall outlet.
Power Cycling
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
6. Restart your computer and check the functionality.
* Turn on the printer/unit and disconnect the power cord from the unit then perform the reset.
==== Partial Reset ====
Press and hold # and 3 button on the unit while plugging in the power cord.
May 24, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
ACER power 1000 has no power at all
change the power supply, if still nothing then motherboard might be gone
Dec 31, 2008 | AcerPower 1000 (AP1000EA380M) PC Desktop
Delphi roady 2 won't power up
You have a bad power plug on the unit. The solder connection are loose. The one have is doing the same thing. The power plug pins have came lose and need to be resolder. Working on how to take the unit apart to solder the connection.
Jun 05, 2008 | XM Radio (XMP6000)
Delphi SKYFi3 XM Radio Receiver Logo
135 people viewed this question
Top Delphi Audio Players & Recorders Experts
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
