Question about SanDisk 2GB microSD Memory Card
How can i remove the write protect in my memory card if it doesnt have a slidable lock
    President:
  • 1,932 Answers
The procedure for removing the right protection is given in the website given below.
please follow the directions and you can remove it.
http://www.troublefixers.com/remove-write-protection-on-usb-pen-drive-or-memory-card-or-ipod/
Thanx
Posted on Jul 21, 2010
I have had this camera for two years and never had a problem. Now when I switch it on the screen shows the message, " Memory card is write protected" and the camera will not function.
On the memory card is a slide lock that locks the card from being accidentally written to or erased. embossed with a lock that is unlocked/locked.
Somehow this slide lock has been moved to the write protection mode/locked. Could have happened if you removed the memory card lately.
Remove the memory card and slide the lock to unlock reinstall the card and that should cure your problem.
Feb 05, 2016 | Nikon Coolpix S3300
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
How to remove write protection from sony memory stick pro duo
There should be a small plastic catch on the side of the card which allows you to write protect the memory stick pro duo. It should have an image of a lock or say locked next to it, if it is locked you won't be able to write to it. Slide it to the unlocked position using a fingernail or a paperclip.
Apr 29, 2015 | Sony Electronics - Others
Netbook manual goclever R103
SD = Secure Digital - which means there is a small (on one side) slidable lock - if locked, you cannot access the card. Check that as probably needs sliding to free the card for use.
Sep 01, 2014 | Cameras
Remove write protection
On the left side of the memory card find the word lock. There is a small slide switch you need to push up. This will remove the write protect. Some computers with built in card readers may insist the card is locked when it isn't. The work around for this is get an external usb card reader. you can use it to get data off it, format it and add data to it that way
Jan 17, 2014 | Electronics - Others
Why wont my p80 allow me to format.
Your memory card is probably write-protected or if not it is busted. To verify if your memory card is locked you can easily remove it from your digital camera, and check for a small lever and set it to 'unlock'.
If this doesnt solve your problem, your memory card is probably corrupted/busted/defective.
Dec 27, 2010 | Nikon COOLPIX P80 Digital Camera
Remove write protection from micro-sd card
  1. Remove the Sandisk SD card from your portable electronic device. Ensure that the SD card can be safely ejected before removing.
  2. Locate the write protect lock. The write protect lock should be on the side opposite the cut-off corner of the SD Card.
  3. Disengage the write protect lock. To do this, gently slide the small switch upward, toward the top of the SD Card. The card should now have write protection disabled.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Mar 03, 2010 | SanDisk 2GB microSD Memory Card
Memory card is locked
There should be a small sliding switch on the corner of the memory card. Look for a lock/unlock symbol and move it to unlock. That should take care of it.
Oct 22, 2009 | PNY 4GB Secure Digital High Capacity...
Locked Card
Take the memory card out of the camera. Look at it carefully and you will seea small tab. Move the tab from the locked position to the unlocked position. Re-install the memory card into the camera and then you're done.
EEee
Nov 03, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
SanDisk 2GB microSD Memory Card Logo
165 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
