Question about Timex Expedition 40141 Wristwatch
No sound after battery replacement
I just replaced the battery to my Timex Expedition and now the alarms do not sound. I can't get them to work anymore. Any ideas??
  • 10 Answers
IS THE BACK ON THE RIGHT WAY THE WRITING SHOULD BE FACING LEFT TO RIGHT AND START FROM 12 O'CLOCK DOWN
Posted on Jul 24, 2010
Timex expedition compass, alarm does not sound since battery replacement.
You will find an arrow head on the outside back of your watch where all the printing is. When you put this lid back on, this arrow needs to be aligned with a notch on the inside edge where the cover goes on. As you are looking at the watch from the back with the cover off this notch is in a northwesterly direction. If you doubt it then just hold the back on without popping it in all the way and hit your mode button to make sure that you hear the beeps again. If you do, then you've found the right spot...
Mar 01, 2015 | Timex Watches
I set the alarm turn it on but get no sound from the alarm.
Yesterday, I have just replaced new battery of CR 1620 but it gets no sound as you. I found that it must be resetted that I don't know how. I'm trying to find it out.
Mar 11, 2014 | Timex Expedition Digital Compass T40611...
My aunt's watch is a timex expedition. it says to push the reset button after changing the battery and we can't find one. The clock works but the alarm doesnt. She had the battery replaced at walmart...
I am sending you a link to instructions for a differnet Timex, but it is basically the same conccept. This link has pictures which will help you figure this out. If you still have troubles....I highly recommend you take to a QUALIFIED jeweler besides Walmart.
http://www.userinterface.com/instruc/timex/timex.html
Best regards. Jewel
Sep 01, 2010 | Watches
Lost the beep on my timex watch alarm
Try taking the back off and orientating it the other way (i.e. turn top for bottom). You don't have to screw it down to see if this will work. As soon as the back clicks in you will be able to hear beeps as you press the buttons
Mar 18, 2010 | Timex Expedition C45981 watch
I recently had my battery changed on a timex expedition adventure tech altimeter watch, now the chime doesn't work and the alarm doesn't beep. Please help. Thank you.
You can attempt to have the circuit board reset if it has an "AC". This may or may not fix the problem. Usually when a sound board goes out you have to replace the whole circuit board or movement.
Sep 14, 2009 | Timex Expedition Adventure Tech Altimeter...
No beep, no alarm, no sound at all after battery replacement and after resetting the watch. The watch is the Expedition.
I think you put case back wrong way ,, or a small spring which connect caseback with watch movement feil during battery change that also ma be a issue.
From
AmFix Jewelry & Watch Repair
203 N. LaSalle St
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Sep 14, 2009 | Timex Digital Expedition watch
Timex Men's Digital Expedition Chrono Alarm Timer Watch battery
hi
please follow the steps to change the battery
  1. Step 1 Make sure the little arrow on the back is aimed to the right. Then, insert a small flat head screwdriver into the notch on the edge, and lever the back open. Place the back to one side.
  2. Step 2 Unscrew the clip holding the battery (if your model has a clip), and remove the battery.
  3. Step 3 Use plastic tweezers to put in a new battery. Do not directly touch the new battery. Screw the clip (if it has one) back on.
  4. Step 4 Replace the gasket that seals the watch. Then lightly coat the gasket with a silicone-based grease.
  5. Step 5 Align the back with the little arrow aimed to the right again, then carefully press the watch between two pieces of wood that are being held by a small vise, until the back seats itself.
thank you....
Apr 08, 2009 | Timex T41091 Expedition Watch
New Battery but Alarm sound doesn't work
Mar 16, 2009 | Timex Expedition 84601 Wristwatch
Timex Expedition alarm beep
good after noon ! maybe the problem of your watch is wrong possition of case back because the speaker or buzzer of your watch is attached on the case back , so open the watch and fix the case back at the correct possition ,!thank you ! god bless !.....
Aug 28, 2008 | Timex Digital Expedition watch
TIMEX MODEL MF13/P8
Press all the four buttons simultaneously your digital clock gets resetted. It worked for me try it out.
Jul 21, 2008 | Timex Expedition 84601 Wristwatch
Timex Expedition 40141 Wristwatch Logo
451 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Geoff
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
