Question about HP iPAQ H3835 Pocket PC
Ipaq H3835 PDA - won't hold charge??
I just bought a used H3835 , and told it was not used for a few years. On the charger, it will start up and show the welcome screen and set-up. It has been on both the docking charger and regular plug-in charger overnight, but as soon as I remove it, the system shuts down and will not turn on. When I put it back on the charger, it brings me back to the Welcome screen and occasionally an error window appears stating that the battery is completely discharged. The orange "charging" light appears occasionally, but not steadily. Any suggestions??
    Problem Solver:
  • 4 Answers
If you purchase a new battery, they usually come with directions and special tools to change the battery. I had the same issue with 2 of mine when I got them at a used electronics store. IF it is the battery that is not working, then replacing it is easy, and you can get a replacement at your local Battery-Plus store.
In my case, one was fixed by a new battery, the other was not, and I actually had to press pretty hard in the cradle to get the second one to work. It never worked out of the cradle, so I gave that one to a neighbor kid to tear apart and see if he could get it working. (I got them for $15, so no big loss.)
Posted on Jun 28, 2008
You will need to change the battery (If you can figure out how).
In the manual there are no instruction and there is little indication just by looking at the PDA to figure out how to replace the battery.
I think the circuitry of charging the IPAQ PDA has some flaws. It will blow up and mess up the battery if there is surge of current flow, and the the battery is already fully charged. For example if you leave the Battery on a charger and let it stay and if due to storm or whatever else power goes out and then comes back on again IPAQ Battery is likely to get damaged. The sudden surges of electricity are of course cause problems ion all sort of products, but IPAQ charging circuit is very little (no tolerance) to cope.
They should have added a resistance to cope with this, even if that meant longer charging time.
So if you do get a new battery, be careful in charging it. As soon *** it is fully charged take it out its charging stand.
Posted on Jun 15, 2008
  • HP Master
  • 13,433 Answers
Seems there is a bad connection with the mainboard and the battery or the battery is dead.
Might need to replace the battery or atleast check the connections inside.
I had 3950 myself few years ago.
Posted on Apr 22, 2008
Is a compaq ipaq h3835 compatable with vista
No, you do not need an upgrade. You'll need to be download only "Windows Mobile Device Center" to your Vista PC instead of ActiveSync. (ActiveSync is not compatible with Vista, instead Microsoft changed the software a bit called "Windows Mobile Device Center" and can be downloaded from Microsoft's website.) Your Vista PC should also recognize your ipaq PPC without needing any driver CD. I hope it helps.
Apr 18, 2009 | HP iPAQ H3835 Pocket PC
Only works while plugged in
i would say def. its the battery thats dead!
Did a quick search for batteries and found a lot and costs about 10-30$ for a battery
and some include a charger as well.
Worth spending if you gonna use it daily!
Dec 27, 2008 | HP iPAQ H3835 Pocket PC
3835 charge light
does the pda work fine otherwise just no light when the battery is supposed to be full?
Jul 30, 2008 | HP iPAQ H3835 Pocket PC
I have an IPAQ 3950 PDA, I bought a in car charger from ebay and after using it my PDA no longer works. It will not switch on, charge on its home cradle or connect to my laptop, the IPAQ is completely...
Thath iPAQ have two security fuses inside,, maybe one blows up when you connect that charger,,, this is not an easy repair work,, you need to have advance experience on electronics,, or take it to an expert service shop,,, good luck!!
Jun 30, 2008 | LG KU990 Viewty
HP iPAQ 1910 does not charge
It could be the mainboard on the ipaq is messed up. Bring it to a local tech maintenance shop
Jun 03, 2008 | HP iPAQ H1910 Pocket PC
Battery won't charge after being replaced
The charger might be bad. Or then the pdas connector is bad, or the motherboard is damaged.
to find out is your charger working you could use a tester to test it or another pda.
If you could get some power into the pda you could use the bootloader to test the device. Its been years since I had my 3850.
Il have to find instructions on how to get to the bootloader but test the other things first.
Drop a comment.
Mar 11, 2008 | HP iPAQ H3835 Pocket PC
The Screen is back and it won't charge
Hello, it isn't that simple as a broken charger. Try the following thing. Connect battery to the PDA, check that the battery LID is connected FIRMLY to the body (there is a contact there that woun't allow the PDA to start if the lid isn't connected properly, you may want to check it too, look carefully for a small black thing and check that it can be pressed). Then connect the pda for half hour to the charger, even if no light or amber led is flashing. Then make a master reset as showed here and connect the PDA to a usb sync cable with your computer. Press simultaneous the soft reset and the power button, then press only the soft reset button. The PDA should start. If not, there is a problem with a DC converter component on the mainboard or the connector I was talking about before. Even if the charger is broken, your PDA should power on from USB cable. Good luck, feel free to ask further questions and always remember to rate replies received from this site :)
Feb 27, 2007 | HP iPAQ H2210 Pocket PC
My PDA took a fall
First try to charge it . If it does not power on try a hard reset. If this does not work and if you are dedicated to your pda, invest a new battery Shop at (ebay, Amazon, Shopzilla,etc) batteries are easily installed http://www.fixya.com/support/p389721-hp_ipaq_h3835_pocket_pc HP iPAQ H3835 Pocket PC Troubleshooting, Support, Repair & Service
Oct 25, 2006 | HP iPAQ H3835 Pocket PC
Ipaq h3835 froze
Try a soft reset first to allow programs to terminate, then try to delete programs, if that fails to work give the hard reset another try http://www.fixya.com/support/p389721-hp_ipaq_h3835_pocket_pc HP iPAQ H3835 Pocket PC Troubleshooting, Support, Repair & Service
Sep 19, 2005 | HP iPAQ H3835 Pocket PC
My H5450 won't charge!
When you charge up your iPaq, do you use the cradle, or do you use the AC-adapter with the little iPaq power converter that came with the iPaq? Try both, and see if it charges up your pda. Try and borrow an iPaq car-charger and see if it charges up that way (the ones that do not need the iPaq power converter). If you are lucky enough to power up the iPaq even for 2 minutes, enable USB fast charging in the SETTING -> BATTERY. Your USB-data-cable or cradle will then be able to charge it up that way...
Sep 08, 2005 | HP iPAQ H5450 Pocket PC
HP iPAQ H3835 Pocket PC Logo
315 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
