Question about Frigidaire FAH106N1 Wall/Window Air Conditioner
I have a frigidaire window ac. THe compressor doesn't shut off. I have to unplug it for the compressor to stop. What could be the problem? Someone told me it could be the thermistor.
  • fmcam3 Jul 20, 2010
    the control panel is electronic. As i looked at the parts diagram there is a (Sensor, ambient temp, thermistor) part and a (Sensor, evaporator temp thermistor) but no thermostat listed.
  • 29 Answers
If it cools properly, it is not the thermistor. It most likely is the thermostat. Turn the knob to the warmest temperature and see if it shuts off. Still no? Then you can open up the control box. (DANGER--line voltage--can shock you) . Unplug the unit, open up the control box, take one of the wires(either one) off of the thermostat, tape it securely and isolated. If the compressor does not run now, then the thermostat is bad.
Posted on Jul 20, 2010
  • johnmalcolm1 Jul 21, 2010
    It would be the evaporator thermister. Somehow it is sensing the air from the room as it enters the evaporator coil
I have a spt wa-2211s AC window unit when i turn it off the compressor keeps running have to unplug it to make it stop running
So the compressor keeps running , fan shuts off and coil starts to freeze??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 03, 2017 | Heating & Cooling
Frigidaire window unit fra18emu2 compressor will not turn off when power is shut off. Must unplug. Why?
Either the compressor relay has become stuck (most likely) or there is a wiring fault internally where power is being shunted directly to the compressor (also possible). Check the condition of the wiring around the compressor start capacitor and, if you see melted wires, there's your culprit. (NOTE: Melted wires all need to be replaced to eliminate possible fire hazard.)
May 14, 2015 | Frigidaire Heating & Cooling
Fac127s1a. It trips as soon as plugged in ....
You will need someone to unplug, mark the wiring to compressor, remove wires from compressor and OHM the compressor to see if shorting to ground, Sea Breeze
I believe it is shot!
Jun 17, 2013 | Frigidaire FAC126P1 wall/window Air...
Brand-new window unit emits musty smell when compressor shuts off
It SHOULD NOT ... (smell in... even in WEST TEXAS).
BRAND NEW... Rush on down and get a good
NEW one.
I would suspect the condensate drip pan is plugged...
Common for AC units ..
But NEVER in "brand new"...
Get that (previously owned (my opinion)) UNIT
back from where you bought it ... Trade it in for a CLOSED BOX... and make your sales CLOWN write up why you are returning it.
Mold can be quite dangerous!!
Carnac the Magnificent
Apr 26, 2017 | Frigidaire Heating & Cooling
I have a Frigidaire Window Air Conditioner and Heater fra18emt2 and the compressor will not shut off
Contact Frigidaire to see if this unit needs to be serviced or if they have limited warranties on the appliances.
Aug 04, 2012 | Heating & Cooling
I turn on ac, and your suppose to wait 3 mins. for compressor to kick on, it does then just shuts rite back off and then makes a humming noise
It sounds like a broken relay. The relay should be attached to the compressor. Unplug the ac, remove the relay and shake it, if it rattles it needs to be replaced
Jun 07, 2011 | Frigidaire FAM187S2A Air Conditioner
Ac compressor not working
This unit is a 220 volt ac unit. 12-2 wiring is usually for 120 violt circuits?
  • Amps: 22.2 / 20.0
  • Watts (Heat): 4900 / 4000
  • Watts (Cool): 1650 / 1625
  • Amps (Cool): 7.7 / 8.3
  • Voltage Rating: 230V / 208V 60Hz
  • Power Cord Length: 5' (6')
  • Horsepower (Cool): 2.49
  • Plug Type: LCDI 6-30P
  • http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRH1822R2
    hope this helps?
    Jun 05, 2017 | Frigidaire Heating & Cooling
    Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
    Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
    May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
    Frigidaire FAH106N1 Wall/Window Air Conditioner Logo
    824 people viewed this question
    Top Frigidaire Heating & Cooling Experts
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Bill Long
    Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
