Question about HP Office Equipment & Supplies
Deskjet f380 wont print on computer command.printer is on & has paper, computer eccepted print job but when I pressed ok nothing happened. 2 days ago similar printing contract the printer didnt react for 20 minutes.
I unpluged the printer , turned computer off rebooted & pluged printer back in
Posted on Apr 22, 2008
Printer takes one paper and does not print
That is nothing more than a driver issue, simply update the drivers from Device manager and it should work
Oct 01, 2009 | HP DeskJet F380 All-In-One Printer
Paper jamming problems with HP DeskJet F380 All-In-One Printer . The paper feeds into the paper feeder but then it seems to get off line and the paper get stuck and actually tears in the feeder. The...
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Thanks
Newton
Aug 29, 2009 | HP DeskJet F380 All-In-One Printer
HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
Hp deskjet f380 paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 07, 2009 | HP DeskJet F380 All-In-One Printer
Flashing red lights and letter E on my hp printer
basically for this printer I have found that just restarting your computer will solve almost anything. make sure there is no paper left jammed in the printer and restart. sometimes you have to delete the print job in the printer que. there should be a printer icon down my your clock, right click, open active printers, and delete your file. restart your computer and try again
Sep 18, 2008 | HP DeskJet F380 All-In-One Printer
Hp printer
hi,
it would be great if you can tell me the operating system that you are using on you computer.
anyways check this out:
for windows xp:
>click on start-->run
>type in services.msc
>press ok
>from the new window called services local, double click on print spooler
>press the stop button
>now press the start button
>press ok and come out of that window.
>close all the windows and restart you computer.
for win vista:
> click on start, inside start search type in services.msc and hit enter.
> then follow the same as above
Mar 14, 2008 | HP DeskJet F380 All-In-One Printer
My HP deskjet F4810 printer keeps going offline
hi dear
this link for your driver
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-40457-1&lc=en&cc=us&dlc=en&product=1128296&os=228
oke....
post in me back
thks
ropp
Mar 12, 2008 | HP DeskJet F380 All-In-One Printer
As described by you , there might be an issue with teh spooler service of your computer , u can follow the undermentioned steps that might help you.
  1. Open a Command Prompt window
key the commands
net stop spooler
2. In the run (Start Search for Vista) type : c:/windows/system32/spool/drivers…look for w32x86 folder.
3. Inside w32x86, there will be folders with the names 2 and 3 (one or more of these may be absent - not a problem)
delete all of the files and sub-folders in each of the 2 and 3 folders, but not the folders themselves. Inside 32x86, there may be other folders with names starting with "Hewlett-Packard", "hphp" or something else; delete these folders also
4. In the run (Start Search for Vista) type : c:/windows/system32/spool/printers: delete any files there. By default, this is where the print spooler stores print files.
5. Open a Command Prompt window
key the commands
1. sc config spooler depend= RPCSS
(note the space after the = but not before)
2. net start spooler
Cleaning from Registry:
1. Take backup of registry:
2. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers
  1. There might be two entries names Version-2 and Version-3 under drivers: click the plus sign against them and remove everything under them.
  2. Then click the plus sign against PRINT PROCESSOR, which is under DRIVERS and make sure there is only one entry i.e., WINPRINT. If there is any other entry, just remove it.
The spooler cleaning is complete.
now reinstall the printer .
Mar 06, 2008 | HP DeskJet F380 All-In-One Printer
Hp deskjet f380
To print from a software application (Windows)
1. Make sure you have paper loaded in the input tray.
2. On the File menu in your software application, click Print.
3. Make sure the HP All-in-One is the selected printer.
4. If you need to change settings, click the button that opens the Properties dialog
box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
5. Select the appropriate options for your print job by using the features available on
the various tabs.
6. Click OK to close the Properties dialog box.
7. Click Print or OK to begin printing.
Nov 08, 2007 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380 Paper Problem
http://www.nodevice.com/driver/company/Hewlett-Packard/page3.html
Oct 01, 2007 | HP DeskJet F380 All-In-One Printer
54 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
