Question about HP Officejet Pro L7680 All-In-One Printer
How to print mirror image on hp Officejet Pro L7600 Series. I want to print on iron on fabric sheet
  • 97 Answers
SOURCE: Using JETCET Print with OKI C5200n Printer
The OKI 5200 is a 'GDI' or Windows only printer and does not support PCL or PostScript languages.
Most if not all of the printers listed support either PCL or PS or an inkjet based language.
I'm afraid you will not be able to print the the 5200 without it's driver loaded on the PDA.
If the 5200 supported PCL you would be able to choose any of the
Color HP Deskjets.
Posted on Apr 07, 2008
websnail
  • 419 Answers
SOURCE: when printing on my HP
The HP88 printhead can dry out and cause clogging in the black part of the K/Y (black/yellow) printhead.
This has been a major problem for a few client schools of mine and for me in my attic space where air conditioning and/or hot dry air causes clogging.
You may want to consider purchasing a new printhead and an alternative black ink supplier (non HP) that uses Dyebase ink instead of pigment as this doesn't clog in the same conditions.
However, please note that if you do this it means you may lose your warranty (certainly on the printhead) and the printout won't be as clear for text as the black ink can "bleed" slightly into other colours. It has however solve the problem of clogging in one school that went through 5 printheads in two terms/semesters until we switched.
Posted on Jan 23, 2009
SOURCE: hp officejet pro l7680
To solve this problem, you need to set the mirror image to 'off' under the advanced tab of the printing defaults and under the advanced tab of the printing preferences buttons. We had this problem for some time and since doing the above this has stopped.
Steve
Posted on Feb 09, 2009
SOURCE: HP OFFICE JET PRO L7500/L7600/L7700
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
Posted on Dec 29, 2009
nonontech
  • 4737 Answers
SOURCE: hp officejet pro 8500 a909a
Press the settings button i.e the button with the wrench icon on the machine. Now select "Print Report" and then "Image on Fax Send" and set it to "ON". Save the settings and try again. It should work.
Let me know if you need further help. Good Luck.
Thanks for using FixYa.
Posted on Mar 24, 2011
Trying to install software for HP officejet L7680 on widows 7 system 64 bit. When installed printer and fax works well. When attempting to scan error message appears. "hp Imaging device not...
when installing the drivers turn off the antivirus software. download the latest drivers from HP, also down load the HP software on the main software page. this is the latest HP firmware and diagnostic firmware.
Jun 21, 2017 | HP Officejet Pro L7680 All-In-One Printer
I have an hp officejet pro l7600
I have an OJ l7600, and the colored ink cartridges pod out on their holdings rendering the printer inoperable. I have tried replacing the cartridges,even though there was ink still available. Even with new cartridges this still happens. What gives?
Jan 20, 2010 | HP Officejet Pro L7680 All-In-One Printer
Prints backwards
You have probably turned on the "Mirror Image" option.
When you go to print and the Print window comes up, select Preferences and then the Advanced tab. Look for the Mirror Image option and Disable it by clicking on the underlined option and change it.
(BTW, the Mirror Image is used to print iron-on images for t-shirts, etc.)
NOTE: If you don't see it on the Advanced tab, look on the Effects tab.
Nov 17, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
HP Officejet J5780 now prints in mirror image. I
Go to printing preferences and change the mirror image option to off and then try printing again. Use this figure as a guide:
Sep 08, 2009 | HP Officejet Pro L7680 All-In-One Printer
How print iron on transfers
Yes, you need to "MIRROR" the image. Go to printer properties and select the ADVANCED TAB. Click on the MIRROR setting then print onto the transfer paper. The image should print out backwards like you are looking at it in a mirror. When you iron it onto a shirt, it will come out correct.
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
Started to print in reverse
Check the printer preferences for the "Mirror Image" option and un-check it - this is used for printing Iron-on transfers for T-Shirts.
I hope that solves your Problem, If so kindly accept it.
Thank You, Arjun.
Apr 02, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printing Backwards
You must have the Mirror image option turned on.
Open a document and select File>Print.
When the Print window opens, select the "Preferences" or "Properties". button.
Click on the Advanced tab. Look for the Mirror Image option. If it says "On", click on it and you will get a drop down menu to change it to "Off".
(BTW, the Mirror Image is used for printing iron-on transfers.)
Jan 09, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
All of a sudden my spread sheet is being printed as a mirror image.
The next time you go to print something, select "Preferences" when the first window opens. On the Advanced tab, under Printer Features look for "Mirror Image". Make sure it is set to "Off". If not click "On" and change the drop down to "Off".
Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Printing mirror image/print
Go to control panel and go to printers or printers and faxes. If you see the printer icon right click on the printer icon and select printing preferences. Under printing preferences click on advance and look for mirror image. Click on mirror image and chage it to off
Oct 29, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
184 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
