Question about HP Compaq Presario F750US
Why won't my laptop recharge? Does not even register power hookup.
  • 221 Answers
Mark, there is a good chance that the power supply is not working correctly.
If you can (or have someone) test the output, it either is not providing the power or the connector(s) is/are bad.
The people at your local Radio Shack may be willing to do the test for you. (since most are Compaq dealers)
Posted on Jul 20, 2010
Trying to hookup my notebook but I can't get to my ISP because it stays Work Offline won't stay off.
need to setup network connection, call you isp and they will walk you through it.
if this helps please rate with comment
Feb 03, 2013 | Dell Inspiron Computers & Internet
Despite of new battery my Asus PRO50 won't charge a 100%
Is it a replacement battery? Are the specs the EXACT match, DC volts and Amps? Some inexpensive batteries do not work well with your laptop, it's a Connector/ pin thing, they don't communicate with the laptop. Try pulling the plug and drain the battery and recharge. Cycle it a 4 times, drain/ recharge. Does your BIOS setup have a Battery Learning section?
Dec 13, 2012 | ASUS Computers & Internet
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
Rdrhow to find recharge componets on a215-s4807 motherboard?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 14, 2012 | Toshiba Computers & Internet
Computer just shuts off when i unplug even though shows full battery
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Jul 07, 2012 | Sony VAIO VPCF134FX/B F Series Notebook
Laptop lasts for less than an hour after charged
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 04, 2011 | Computers & Internet
I had my Fujifilm Pink Camera for Christmas. It was working and everything was fine. It was charging and when i plugged it into my laptop is loaded up straight away. I was taking some photo's and the...
Try replacing the batteries. Unless the camera came with rechargeable batteries, they usually have to be replaced. Some pc's do not have the capabilities to recharge batters. Double check your paperwork that came with your camera.
Aug 15, 2011 | Fuji FinePix Z5fd Digital Camera
My hp 540 in battery mode while powered on switches off automatically within 4 second even before display appears, booting takes place whereas in adaptor it is reatsrting automatically
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Apr 21, 2011 | Computers & Internet
Toshiba satellite M55 not turning on
Either the battery is faulty, or the charger is faulty.
Check the fuse in the mains plug, or even the power point you are using could have a bad connection.
Test using a lamp that you know works or a radio or something and try the charger in another outlet to find the fault.
May 24, 2009 | Toshiba Satellite M55-S135 Notebook
HP Compaq Presario F750US Logo
120 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
