Question about Bosch PB10-CD Radio/CD Boombox
Battery charger not charging battery - Bosch PB10-CD Radio/CD Boombox
  • 1 more comment
  • krzysztof Dec 14, 2008
    i try charge battery and show mi low battery
  • Anonymous Apr 26, 2009
    I have the same problem, at first I thought it was the batteries so I went out and bought a charger and low and behold batteries were fine. I've switched to Rigid and had much better luck, bosch might make some quality stuff but that radio fell short in my opinion.
  • Anonymous Apr 27, 2009
    I have the same problem with my Bosch Radio and I tried contacting the company and they told me the Bosch Radio is unserviceable in other words if its broke they wont fix it. So unless you can find someone outside of bosch to work on it its just an over priced GFCI.
  • 136 Answers
Contact the company by website. i have heard too many problems with this unit. it might be recalled
Posted on Apr 01, 2009
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Jan 23, 2016 | Ryobi Garden
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Makita battery charger wont charge
If both lights on the charger are flashing it is indicating you have a bad battery and the charger will not charge the battery. The charger has circuitry that tests the battery and if it 'thinks' the battery is defective it will not attempt to charge it. The only way to verify whether it's the battery or charger is to try charging your battery on another charger or try charging another battery on your charger. Most of the time it's a bad battery.
Aug 02, 2012 | Makita DC18RAX230 230-Volt LXT Lithium-Ion...
Can i over charge my mobility scooter go go pride
Yes you can overcharge a battery, it all depends on the charger your using. Most chargers are single stage chargers. Most scooters come with a single stage charger. My scooter has a built in single stage charger What this type of charger does is output a constant 24v @ 4amps.The problem is batteries amperage requirements decrease as the battery charges. An overcharge will occur when the battery is charged. It requires very little amperage to maintain a charge on a fully charged battery. A single stage charger like mine will output 4amps regardless of the state of charge of the battery. Batteries bring charged with single stage chargers loose their electrolyte. What happens is overcharged batteries break down the electrolyte into oxygen and hydrogen. So overcharging will cause a battery to "boil-out" its electrolyte. Batteries don't work without electrolyte. In the old days there were only single stage chargers. That was the state of the art back then. So to cope with the constant overcharging batteries had refill ports where you could replenish the electrolyte using distilled water.
Scooter batteries are far and away different from the lead acid of the 1970's. Scooter batteries are sealed, they are deep cycle, they use a glass mat soaked in gelled electrolyte. These glass mat batteries optimize the electrolyte used so they can use allot less of it. These newer batteries have a lot more power in a lot smaller package but they have a draw back, they must be charged properly. You can absolutely can not charge these batteries with a single stage charger. Actually you can charge with this device but you will loosed electrolyte each time you charge.
I use a three stage charger 24v @ 5amp. This charger s different from a single stage. Its what they term a "smart charger" it monitors the state of charge of the battery. As the battery charges it turns down the amperage. When the battery is fully charged the amperage is turned low enough were the charge is maintained. The entire charging process is designed to preserve electrolyte. In short this type charger will not overcharge the battery.
Click here to see the charger i currently use.
http://www.amazon.com/Sealed-Battery-Charger-3-Stage-Fan-Cooled/dp/B0051WHAU0
Jul 30, 2012 | Health & Beauty
Included in my Ryobi printed instructions are the statements: 1-"Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode. 2-"To obtain the longest...
Any battery left in a charger is still hooked up to a circuit. Depending on the charger this can mean a slow discharge is possible. Ryobi's Maintenance Charge Mode means the charger will 'refresh' the battery at regular intervals, usually every 30 days. A battery's lifespan is determined by how many times it is discharged/recharged so to get 'the longest possible battery life' it is desirable to reduce the number of times a battery is recharged. One way is to use the battery until it is dead or near so another is to remove the battery from the charger when it's fully charged to reduce the number of times the charger refreshes the battery.
Dec 23, 2010 | Ryobi Multi-Volt Battery Charger
The radio is not charging has new battery
Check your battery contacts on/in the radio, battery and charger. Clean with a pencil eraser if needed. If your charger will accommodate the battery alone, try charging the battery outside the radio. Does the charger's light (if any) come on and stay on when the battery/radio is attached? If so, your charger is working properly. If the light (if any) on the charger is flashing you may have a shorted or bad battery. Check your user guide to the radio/charger for more information. Finally, periodically a battery has too low of an initial factory charger to start charging on the charge immediately. Try placing the battery on the charger for 3 complete charge cycles, and see if it will then charge. If the battery is new, you might want to contact the vendor for a replacement.
Aug 22, 2009 | Yaesu Radio Communications
Motorola CP040 charging time
The rapid rate charger WPLN41__ will typically charge a battery in 90-120 minutes. Your battery should be depleted or nearly depleted when you place it in the charging stand. Be certain your radio is always turned off, when charging an attached battery. The NiMH battery will generally go 12-16 hours on a charge when new. If you work an eight hour shift, you might see if the radio will go 2 days on a charge. Later as the battery ages, you will need to charge it nightly. (Think of putting it in the charger as putting it to bed at night.)
Rapid charging is necessary on NiMH and Li-Ion batteries. They require a "hotter" charger, a fast rate, to completely charge the battery. It will not harm this chemistry of battery. It is safe to leave the battery on the charger overnight, or for a weekend. We would not recommend leaving the battery on the charger longer periods of time, as that will age the battery and reduce its life.
(Sidenote: Frequent rapid charging will however reduce the life of a NiCD battery.)
Aug 12, 2009 | Motorola Radio Communications
Schumacker battery charger problem?
You are charging. The meter corresponds to the level of charge in the battery. Try setting to 10 A for 4 hours, battery should be half-way up. To determine if battery id dead.. leave battery off charger once it is fully charged...test with a voltmeter after 10 min.....battery should still be above 12v...after1 hour it should still be above 12v...if not battery is spent.
Mar 11, 2009 | Schumacher & Fast Charge Starter Charger
Battery charge
Did you cleaning the contacts on charger, If so then go to a camera store with your battery and charger and try there battery in your charger, Then you can narrow down the problem, I think your charger is bad. TC
Dec 06, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Bosch PB10-CD Radio/CD Boombox Logo
265 people viewed this question
Top Bosch Audio Players & Recorders Experts
wayne-m
Bill Boyd
Are you a Bosch Audio Player and Recorder Expert? Answer questions, earn points and help others
