Question about Garden
Outdoor exterior light with motion sensor. No matter what we try to do, we can not get the motion sensor to work properly. The light stays on all the time, and we are going through light bulbs quickly as a result. Also, bugs are accumulating at the front door for the light. This is the second Hampton Bay light fixture for outside we bought. Thought maybe the first fixture had a defect. Other homes in our neighborhood have their outdoor light working correctly. The homes in our subdivisin were built in the late 1960's, and the electrical wiring is just Romex with no conduit. Just two wires, black (hot) and white (grounded), no bare or green (grounding) wire.
    Guru:
  • 468 Answers
Thank you for contacting Fixya. This is Anil.
I understand that the motion sensor is not working on your outdoor exterior light. Let me try to help you with it.
Things You'll Need: An electrical meter
Step 1
Find your sensor. Interior lights have sensors on the switches and exterior lights have sensors directly on the light. Look at your sensor and make sure nothing is blocking it.
Step 2
Electrical Meter
Once you have established nothing is blocking the sensor remove the light or switch (depending on where the sensor is at) and using an electrical meter determine whether there is electricity running to the box. If there is no power the breaker may be tripped. If power is there that means your sensor has gone bad.
Step 3
If the sensor is bad you need to go to your local electrical supply store and buy a new sensor, if the sensor is on the light). If the sensor is on the switch you will have to go buy a new switch.
Step 4
For light sensors: The sensor will have an incoming power wire and an outgoing power wire. The incoming wire needs to be hooked to the wire coming from your breaker panel. The outgoing needs to be hooked to the hot wire (which is usually black or red) for the light.
For switch sensors: Depending on the type of switch the wiring process is different. Your best bet would be to take the switch with you to the store and find a switch like it. In which case wiring instructions will be in the box.
Tips & Warnings
A single pole switch will have two gold screws and a green screw
A three way switch will have two gold screws , a black screw and a green screw
A four way switch will have 4 gold screw and a green screw
This will help you decide what type of switch to buy
Be sure the power is off before working on your light or switch
I believe the above resolution should resolve the issue, however, if you need anymore assistance, please feel free to contact us. We will be glad to help you. I also request you click on Accept so that I get the credit.
Thank you. Have a Great Day.
Regards,
Anil.B.R
Posted on Jul 20, 2010
I have an installed PIR exterior motion sensing light, but no instructions on how to set the controls. Now, if it senses motion, it will stay on for hours.
the sensor has at least 2 knobs maybe 3. one show hands of a clock one show sun. one may show sensitivity. the adjustment is low to hi the wider the adjustment the greater the setting check out this picture on ebay for the icon.
https://www.ebay.com/itm/Outdoor-12M-PIR12V-PIR85-265V-Security-PIR-Infrared-Motion-Sensor-Detector-GF-/292078238929?var=&hash=item4401383cd1:m:mRSg-Rlk4nJMZJH-BiKb2gQ
good luck
Oct 20, 2017 | The Home Security
My motion outdoor light is not turning off.
there can a few reasons for this happening
(1) something is moving within its range , this can be a bush or tree branch
(2) range /sensativity set too high use proper adjustments
(3) some models have a constant on mode that happens when you cycle power too light, turn pwr off and leave off for 15 min then turn back on
(4) lighting , the flashes of intense light drive these things crazy , if a strike comes close , sensor will become perm blinded and stay on
(5) light is defective
Feb 26, 2015 | OUTDOOR Home Security
My Defiant LED outdoor white Blade Motion Security stays on all night
You may need to set the parameters once chosen which means you need to hold the set button in for at least three seconds once you have selected your choices.i usually set new up in the house and then check the duration of the light before installing in situ.
Jan 28, 2015 | OUTDOOR Home Security
I have set all the switches to the left TEST, Low sensitivity and Dual brite OFF and this light stays on all night??
putting the switches on test bypasses all the sensors leaving the light on all the time the test selection is only there to see if the light is working
Jan 15, 2015 | Defiant Flood Lights. 180 Degree Outdoor...
I have a 180 degree Defiant Outdoor Motion Security Light. It was working fine for 2 weeks, but now it stays on all the time. I've tried toggling it to Test and then back to 1 Minute and no change.
I am having the same problem. The manual says to avoid plugging into the same circuit as motors & fluorescent lights. Mine is on the same circuit as a freezer. I'm going to try changing the AC outlet to see if that helps. Good luck!
Sep 05, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
I want to replace my existing single bulb porch light with a 2 bulb motion activated light. It would be operated with the existing switch. Is this ok to do?
Yes. Must keep switch turned ON.
Outdoor lights will only come on when motion is detected, otherwise light bulb does not come on. So the indoor wall switch does not work as override since the motion sensor takes over as the sole switch.
Copy following link for wiring illustrations:
http://waterheatertimer.org/How-to-wire-occupancy-switch.html#motion
Other solutions include adding separate motion sensor light nearby and keep porch light so you can turn on-off when desired.
Another option is to add photocell to outdoor light so it turns on automatically at dusk.
Another option is to use outdoor yard timer with dawn-dusk capability:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Another option is to replace indoor wall switch with with dawn-dusk timer, that can also be used as ordinary on-off switch so you can turn porch light on-off when desired. Timer such as Intermatic ST01C offers simple 2-wire connection.:
http://waterheatertimer.org/ST01C-program.html
Gene
h
Aug 18, 2013 | Electrical Supplies
Motion sensor outdoor light won't go off
How long has this been going on? Has this light fixture been updated recently? Has the lite switch been changed that operates this fixture?
Feb 23, 2013 | Cooper Lighting regent light BRZ Motion...
I need to reset my outdoor lighting == motion detector lighting after a bulb blew. The light just stays on -- no dimming. Is there a catch to how to reset the lighting/
hold down the reset button and stay behind the sensor. Mine does this exact thing in lightning storms it may take a few tries. Good Luck
Nov 09, 2010 | Garden
Have Cooper lighting outdoor motion detected flood
Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
Jul 18, 2009 | Desa International 240 Deg. White Twin 150...
Garden Logo
163 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
