Question about Mitsubishi WD-62525 62" Rear Projection HDTV
My mitsubishi wd-62528 has a constant rapid green blinking light on timer and wont go out. had lamp replaced and reset but wont even come on.
  • Mitsubishi Master
  • 8,617 Answers
Thats a common problem most likley caused by failed capacitors on the DM and the power board. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which contains the capacitors and the CD with instructions for the repair.
Posted on Jul 20, 2010
Where are the capacitors that need replacement located on the Mitsubishi WD-62528.
Look for ones that are bulged on the tops and replace those, if you don't see any bad ones your going to need a ESR meter to test them
Jan 05, 2018 | Mitsubishi WD-62528 62 in. LCD Television
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have a 62inch Mitsubishi wd-62528 when I plug it in the timer power light blinks green rapidly, it turns on once and not for long then shuts off with no light
There should be a system restore button on the front that you can use a ball point pen to press. If you hear a difference if operation (like the fans starting up) then you have reset the system. However if it does not come on and light up the screen then you are likely to have a bad lamp. The lamp has an access door either on the front or the back of the set and is usually on the back. Take the lamp out and inspect it for breakage inside the bulb. Also look very carefully at the root of the filament in the center for bubble like of the glass. If so it is bad and needs replacing. The best place I have found to get a lamp w/housing is pureglare.com
May 24, 2011 | Mitsubishi WD-62528 62" LCD HDTV
It will not turn on
Try to unplug it for a minute, plug it again and see if the green light blinks for about 2 minutes. After that you will probably be able to turn it on. But the blinking light tells you that is time to replace the lamp.
Apr 25, 2009 | Mitsubishi WD-62528 62" LCD HDTV
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
Dec 17, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
1,163 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
