Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Mit tv 62725 with flashing green light
Please forward to MAndary@aol.com all information that you have to repair ourselves. We had the service man out, wanted 750.00 to repair.
thank you,
  • 2 more comments
  • thustonsmi Oct 02, 2008
    I have the same problem. Please forward repair info.
    Thanks
    thustonsmi@aol.com
  • Anonymous Oct 04, 2008
    the green timmer light keeps blinking and the tv will not come on.
  • Tony Moraga Oct 14, 2008
    I have the exact same problem, I have taken off the back cover, but can't find the DM module to replace the capacitors, can you please help me locate the DM module in the rear of the tv, thank you in advance.
  • Badandy55 Oct 14, 2008
    wd62725 flashing greenlight would like some info on what capacitors to replace and on what boards ,I have repair manuel
Hello there,
I have wd-62725 dlp, timer light blick, no stop, I replace all the cap's 1000mf 25 volt, ( 12 capacitors) from the 3 boards, plug tv to power out let (125 volt,) no power same flashing light, lamp is good, all I hear is the click from power supply, tv is very clean, no service manual,
please help.
thank you very much.
Posted on Oct 14, 2008
  • telestereo Oct 29, 2008
    hello there,
    i replaced all cap's on all 3 boards ( power supply, FTM and DM boards 1000mf 16 volts) still flashing light, removed the FC connector from the FTM board, after 70 seconds green blinking light stop, now I now the problem is on the FTM board, what else can be bad on the FTM board?
    any tip's?
    President:
  • 3,130 Answers
I have sent out that information.
Posted on Apr 23, 2008
WD-62725 Put new bulb in, plugged up tv and get a green flashing timer light. TV does not come on.
Replace the DM capacitor. You can get the V26 DM rpair kit from www.tvrepairworld.com which has the replacement capacitors and the CD with detailed repair instructions.
Dec 25, 2009 | Mitsubishi WD-62725 62" Rear Projection...
WD 62725 timer light continusly flashes green TV won't turn on! Push reset button as soon as you release it ,it starts flashing again. Unplug TV 3-4 Hours No help.
The V26 DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the replacement capacitors and the step by step instructions on CD
Dec 07, 2009 | Mitsubishi WD-62725 62" Rear Projection...
50 in mits tv wont power on. green reset light
Hi, It's either the lamp or the power supply capasitors. Thanks.
Sep 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green light will not reset. TV will not turn on.
something is not quite right here. usually mits has a good rep, but this doesn't sound quite right. i suggest you contact mits customer service about your experience.
Sep 11, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi wd-62825 dlp
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
michtech
Feb 13, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Screen won't turn on --flashing green/solid green power light
Your main boards are bad. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor
Jan 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mits 65" wont power on
set could have a short and be in shut-down mode ...making just a blinking green light on the front.
remember your standby circuit is always on waiting for a remote command and can be damaged by surges in the line from storms.
please add a surge protector in future after you found the failure.
May 11, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
289 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
