My sound is not working. I have windows Vista. I've tried everything, reloading drivers etc...
    Guru:
  • 468 Answers
Thank you for contacting Fixya. This is Anil.
I understand that you are unable to hear any sound from Computer.
There are various method to analayse the cause of the issue, please follow the steps below:
Method 1: Restart the computer
Restart the computer at least one time after you install a Windows Vista service pack to verify that all processes related to the installation are complete.
After you restart the computer, determine whether you can hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 2.
Method 2: Try another sound device
If it is possible, try plugging a different sound device into the computer. For example, if you were using speakers, try a different pair of speakers or a set of headphones to make sure that the problem is not related to the sound device.
Determine whether you can hear sound. If you can hear sound, there is a problem with the original sound device and the issue is resolved. If you cannot hear sound, plug the original sound device back into the computer, and then go to Method 3.
Method 3: Unplug the computer speakers
Unplug the computer speakers or other sound devices that you may be using, such as headphones, from the computer and then plug them back in to the same port. Most sound cards that are compatible with Windows Vista include a feature that detects sound devices plugged into the audio jack. This procedure may prompt the audio detection feature to detect and configure the sound device to make sound.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 4.
Method 4: Verify that the default sound device is set correctly
After you install a Windows Vista service pack, you may find that the default sound device, also known as the playback device, was changed. You may also find that the sound quality has changed. Make sure that the default sound device is set correctly for the sound device that you are using. To set the default device, follow these steps:
Click StartCollapse this imageExpand this image, type Sound in the Start Search box.
Click Sound in the search results at the top of the Start menu.
Click the Playback tab. Notice the check mark next to the default device. For most users, the default device is Speakers. Make sure that your audio settings are configured as expected. Follow these steps:
On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect. When you finish, close this window to return to the previous window.
On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
Select the sound device that you want as the default sound device, and then click Set Default.
Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5.
Method 5: Verify that a sound driver is installed
Without a sound driver, you will not hear sound. Make sure that a sound driver is installed. To do this, follow these steps:
Click StartCollapse this imageExpand this image, type Device Manager in the Start Search box, and then press ENTER.
In the Device Manager dialog box, expand Sound, video, and game controllers.
If there is a speaker icon next to the sound driver, the driver is installed. If there is a yellow question mark next to the sound driver, the driver is not present or will not load.
Go to method 6 to reload the current sound driver and test for sound.
Method 6: Reload the current sound driver
If you discovered in method 5 that the sound driver was not installed, or if you discovered that the sound driver was installed but is not working, try to reload the sound driver. To do this, follow these steps:
Locate the audio device that was included with the computer.
Right-click the device, and then click Properties.
Click the Driver tab, and then click Uninstall.
Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
You receive a message that states that a hardware device is being installed, and then the uninstalled audio device appears in Device Manager.
Close the Device Manager dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If the current sound driver did not reload or if it did reload, but you cannot hear sound, try method 7.
Method 7: Update the current sound driver
If the current sound driver does not seem to be working, see whether there is an updated sound driver that you can install. To request an updated sound driver, contact the manufacturer of the sound driver.
For information about how to contact hardware and software vendors, visit the following Microsoft Web site:
http://support.microsoft.com/gp/vendors/en-us (http://support.microsoft.com/gp/vendors/en-us)
Note In some cases, the manufacturer may instruct you to uninstall the current sound driver and to delete the driver files. To do this, follow the steps in method 5, but at step 6, click to select the Delete the Driver Software for this device check box.
Also, please visit:
http://windows.microsoft.com/en-US/windows-vista/Tips-for-fixing-common-sound-problems
http://support.microsoft.com/kb/948481
I believe the above resolution should resolve the issue, however, if you need anymore assistance, please feel free to contact us. We will be glad to help you. I also request you click on Accept so that I get the credit.
Thank you. Have a Great Day.
Regards,
Anil.B.R
Posted on Jul 20, 2010
I have a Netgear Wireless N150 router. It has been installed on our 2 computers. However, I had to reinstall Windows Vista on one and when I tried to reinstall the router, it tells me "No working...
Sounds like the driver for the network adapter has not be installed following the re-install of vista
to verify
go to start-->control panel-->System
Click on 'Device Manager'
Look for any devices that have a question mark or exclamation mark next to them
I suspect you will find something like 'Ethernet controller' which wont be configured correctly.
You will probably need to download the driver, using your other machine and then transfer to the problem machine and update the driver
If you need help identifying the driver then please provide details of the make/model of your PC.
If this doesn't solve the problem then let me know before rating this answer and I'll try to help you further
Good luck
Sep 06, 2011 | Computers & Internet
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Down graded to XP from vista and sound not working
Actually this notebook is not officially designed to work on Windows XP, however there are some unofficial drivers available for windows XP, you may try downloading the sound drivers from:
http://sites.google.com/site/sriksang/software/drivers
I'd recommend to install all the drivers from this page.
In case the drivers on this site do not work, let me know I shall provide you other links to the drivers.
Please rate this solution.
Feb 19, 2010 | Compaq Presario 700 470024-192 Notebook
Hp pavilion loads to windows users then once the user is selected it acts as if it wants to load then everything goes solid pink. tried many different monitors
Sounds like you have a driver problem.
If you are running vista, go to your recovery manager and reload your hardware drivers.
If you are running xp, remove your video drivers and reload them from HP's website.
Oct 22, 2009 | HP Pavilion dv9000z Notebook
No sound out of my speakers, i have a sony viao vgn-ar630e, i just reloaded windows vista along with all of the updates and it shows in itunes and varios other media players that a song or video is playing...
If the sound was working before you reloaded VISTA, you have driver problems.
The best way to fix your problems is to check your device manager for flags and if found, remove them.
Next, go to sony's website and download your VISTA drivers and install them.
Do you see a speaker on the lower tool bar ?
Oct 09, 2009 | Sony VAIO VGN-AR630E Notebook
Sound is not working
Try doing a check in the device manager for flags.
Remove any flags and remove any external devices.
Reboot the unit in safe mode and see if you get the same error messages2.gif.
If so, you can remove your sound and modem drivers in the device manager and reload from restoration disks or partation. Or you can allow windows to reload the drivers after a reboot.
If you are useing VISTA2.gif the best way is to type in recovery manager, and choose re-install hardware but you should have removed the audio and modem drivers first.
Hope this helps, Please readers rate your techs
Sep 26, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
No sound from speakers with windows vista
Check to see if the cable has been connected from the CD drive to the Sound card or the mother board. You may also want to reload your CD drive software or make sure that the drivers are properly loaded.
Sep 03, 2009 | Computers & Internet
Vista Home Premium crashed. Reloaded, www, graphics driver no-go
I would try to use the System Restore feature, if you have not already. Choose a date prior to when it crashed on you and it should work.
Mar 17, 2009 | Microsoft Windows Vista Home Premium with...
Sony Vaio sound...
Adam,
The sony VAIO Pcv-j200 only runs with Windows 2000, windows Me and windows xp. The current operating system Vista on your computer right now will work but some of the features of it may not. The link below shows all the drivers for your unit for diffent operating systems (not vista). What you can try to do is to download the audio driver for windows xp
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCVJ200&LOC=3
Jul 05, 2008 | Sony VAIO PCV-J200 PC Desktop
Compatibility with Windows Vista
Sounds like you have a driver issue. Here is a link of all the sound cards that are supported by Vista: http://www.iexbeta.com/wiki/index.php/Windows_Vista_RC_1_Hardware_Compatibility_List#Sound_Cards I don't see your card in there, yet. Check with the manufacturer for updated drivers.
Apr 05, 2007 | Harman Kardon HK695 Computer Speakers
Computers & Internet Logo
52 people viewed this question
Alun Cox
David Payne
David Payne
