Question about GE WBVH6240F Front Load Washer
Door gasket leaking
How do I remove the door gasket to replace it on a GE wbvh6240 front load washer>
  • dwlee39 Jul 21, 2010
    I know it is the gasket / door seal as it has a small tear in it, can anyone tell me how to take get it out??
  • 3 Answers
My GE washer model wcvh6400j0ww was leaking too. The repair person thought the same thing the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Posted on Jul 20, 2010
What is the procedure to take the front off, particularly the top console? Thanks in advance!
Posted on Jul 28, 2010
My question is; the washer,model,wbvh6240 has any filter
No , all new front loads have a self cleaning filter. Therefore nothing needs to be emptied or clean. The little trap door in front of the washer is to drain it in case of a power failure when the washer is full of water. .
Mar 15, 2011 | GE WBVH6240F Front Load Washer
Front door leaks
The door gasket is bad this page will help http://www.appliance-repair-it.com/GE-front-loader-washer.html
I know the page says GE front loader but replacing the door gasket is the same.
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We discovered that our front door inner gasket is torn. Therefore, it's leaking during every load out of the door. I will be ordering the part but concerned that I won't be able to replace it. Do you...
If you've not done this before, expect to spend a lot of time. I've replaced these without disassembling the washer's front, but it's an arm-twisting experience to put the inner part of the gasket on, and to attach and tighten the clamp holding it. Haven't tried removing the front panel, if you can, do it - the job becomes much easier.
PS Check shocks and if the washer is leveled enough, door gaskets tear from excessive loads and excessive vibration.
Mar 29, 2010 | GE WBVH6240F Front Load Washer
GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Feb 07, 2010 | GE WBVH6240F Front Load Washer
My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
Jul 16, 2009 | GE WSXH208A Front Load Washer
Replace rubber gasket
Replace the machine with a top loader and you'll never have a leaking gasket again! Worked at National Linen for a while and the floors had drains in them and were always wet! Needless to say the pros have the same problem you do! ;)
Apr 22, 2009 | GE WBVH6240F Front Load Washer
Washer
I have notice this problem with a lot of front loaders. I would check the manufacture warranty to see with is covered and if you bought an extended warranty, use it, keep your receipts for your previous purchases.
Dec 11, 2017 | GE WBVH6240F Front Load Washer
GE WBVH6240F Front Load Washer Logo
737 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
