Yes you can - yes it is worth it. First unplug or turn the breaker off to your unit. The bottom bake element is held in by 2 screws at the back of the oven. remove both of them and gently pull out the element a little. there are 2 wires attached to the element either by 2 more screws or push in connectors.
A lot of the time you can see where the element is burned out but sometimes you may have to check it for continuity with an ohm meter to tell if it is bad.
Testimonial: "this gives me courage to go the next step! Thanks"
