Question about Bose 3·2·1 II System
I am only getting output from one speaker, the right side. I reversed the cables and the problem stayed with the left wire and connector plug. Both speakers work.
    Genius:
  • 1,354 Answers
Hi
i thing you have problem with your Woofer auodio output pin try to change that it will solve the problem
Posted on Jul 20, 2010
No volume on all left side speakers
Determining the Cause of the Problem Let's assume our system has a head unit, a crossover, a two channel amplifier and two door speakers with only the right speaker working (the left speaker is not working). If the door speakers are behind the door panels then we want to make sure the speaker is the problem before removing the panel. We'll work backwards starting with the amplifier and ending at the head unit. Testing for a Speaker Problem With the vehicle and the stereo turned off disconnect the speaker wires for both the left and right speakers at the amplifier. Now connect the left speaker to the right amplifier output (which we know works). Turn on the stereo system and make sure the balance is set to the middle position.If the speaker still doesn't work then the problem is somewhere between the amplifier and the speaker Testing for an Amplifier Problem Now we'll need to see if the amplifier channel is bad. Put the left speaker back on the left amplifier channel and the right speaker on the right amplifier channel. This returns the speaker wiring to its original configuration. Again, with the vehicle and stereo off unplug the RCA cables from the amplifier's input and switch them so the left cable is in the right input and vice versa. Turn on the stereo system. Testing for an RCA Cable Problem For any intermediate components between the amplifier and the head unit follow these steps for each one. We only have a crossover so we'll just do this once. Begin by testing the RCA cables between the intermediate component and the amplifier. Unplug both RCA cables from the intermediate component's output. Now plug the working channel's RCA cable into the non-working side of the crossover. In our case the working channel is the right so plug the right RCA cable from the amplifier into the left side of the crossover. Turn on the stereo system.
If the right channel continues to work then you know the problem is in the RCA cables between the amp and the crossover. esting for a Crossover or Equalizer Problem At the input of the intermediate component (in our case the crossover) flip the RCA cables around (left to right input and vice versa). Turn on the stereo system.
If the right channel continues to work and the left channel continues to not work then you know the problem is in the intermediate component. Replace or repair this component.
If the problem is now in the right speaker and the left speaker works then the problem lies before the crossover. Turn off the stereo system and return the RCA cables to their normal places.
Testing for a Head Unit or RCA Cable Problem Pull out the head unit from the dash so you can access the RCA cables. Unplug both RCA cables from the head unit. Do not disconnect any other wiring. Plug the right RCA cable into the left channel of the head unit. Turn on the stereo system.
Sep 29, 2016 | Cars & Trucks
I have a WahlDorf sound system no instructions...its WD310HT Home Theater.its a subwoffer an 5 speakers how to connect to TV or DVD?
there is no info for a 310,but,there is for a 305,you need to make some cables for it,you need some rca cables with one end cut off,the rca plugs into the tv audio output,the two wires from each one,go into the push connectors,treat the outside wire as neg(black) and inside wire is always pos(red),,the top 2 push posts on the left are for the left audio from your tv,the 2 posts on the right are for the right tv audio,there are 4 more connectors for another device,like a dvd etc,push connectors operate by pushing in on them and pushing the bare wire into the little hole and releasing,
25715906-ghuqylfbvqx2ddmcce1obb43-5-0.jpg this is the only pic available,the 4 push connectors on the right are,tv right,pos,,tv right neg,then other audio right neg.,,the bottom one is other audio pos,,,,the 4 on the left side are left tv audio pos,,then left tv audio neg,then other audio left nrg,,then left other audio pos,,,
25715906-ghuqylfbvqx2ddmcce1obb43-5-2.jpg this is like what you need,the red is positive and bare is neg
May 27, 2015 | home Audio Players & Recorders
No bass in righthand speaker
First try swapping the cables and put the left speaker cables in the right hand amp output and the right speaker in he left output. If the problem stays in the right hand speaker and does not move to the left as I suspect should, then it is a problem with your speaker crossovers. You may have to open up the speaker and check the wiring and then crossover. If the problem changes and appears in the left hand speaker you have an amp problem.
Jun 08, 2014 | Mission M73 Main / Stereo Speaker
How do I hook up my lifestyle 20 . I bought it second hand and my speakers have wires.
Hi Mark,
I'm assuming you have the original speaker cables that came with the system (it looks like the connectors on the small speaker side are not standard connectors). If that is the case, the two smaller speakers should connect to the Left and Right 'Output to Cube Speakers' plugs on the larger subwoofer box. A 3rd cable from that subwoofer box should connect from the "audio input" connector on that box to the to the "Speaker zone 1" plug on the main unit.
Plug both the main unit and the subwoofer into power outlets, turn them both on and you should be all set. If you click on the link below, pages 7 - 8 of the owner's guide have a good description and pictures of this configuration. The rest of that guide may come in handy too.
Bose Lifestyle 20 Owner's Guide
I hope this helps,
- Kevin
Dec 30, 2011 | Bose Lifestyle 20 System
Rowe r92 sound problem
Moving the wire indicates the speakers are OK. Try reversing the 3 pin plug from the cartridge. If the problem stays on the same channel, it is probably a preamp board issue. If the problem switches channels, you have a bad wire to the cartridge or a bad cartridge.
Nov 16, 2011 | Audio Players & Recorders
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
Left speaker is not working on my 2.1 speaker system...
A few things can cause this to happen. First we should check the computer. Take a pair of headphones or other speak set and check if sound comes from both sides. If to then the computer output is correct, else the computer is channeled to output to one side.
To change sound settings, if this is windows, go to your control panel and look for sounds option. In there you can change speaker settings, change volumes. On the volume control you can balance the speaker output. center the slider to make both correct.
If sound is coming from the PC correctly with a test object you will need to check your speakers for a fade option, not many have this it is just a suggestion. If no fade option exists, make sure the plug is totally seated. Improperly seated plugs will cause only 1 channel to be outputted or none.
If all the above does not help then check the cabled leading form the computer to speakers for damage as well as checking the wire between the left and right speakers for damage. Many times the output lead from the right to he left gets damaged from stress or other things and will stop output. Wiggle and pull the wire gently in each direction if they don't physically look damaged to see if sound is produced. if it is then the wire is internally damaged or loose from the speaker.
good luck
Mar 14, 2010 | Altec Lansing Audio Players & Recorders
No output from right side speaker jack
audio board located inside the mainboard console to the right trace your speakers wire to bd, disconnect the three leads, 3 phillips screws, and examine bd for burns. If yes, ebay the board id for a replacement.
Apr 24, 2009 | Dell W4201C 42 in. Plasma HDTV
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Connecting Durabrand SA51AR to computer
Each "red and white" represent a stereo pair (Right and Left respectively. What type of connectors are on the SA51AR? I will guess TS (tip sleeve) or Phono for the sake of this answer.
It sounds as if the PC's outputs are stereo TRS (tip, ring sleeve) 1/8" female connectors, which is normal. TRS connectors carry both the Left and Right signals whereas Phono and TS only carry one signal each.
Radio Shack has converters which will allow you to plug a "red and white" connector in one end (either TS or Phono) and will provide a TRS output on the other which will plug into your PC's sound outputs. That way, the Red/White pair for "Side Speakers" (front L/R) can plug into the one grey jack and the Rear (rear L/R) can plug into the black-jack, etc.
Feb 07, 2008 | Audio Players & Recorders
Bose 3·2·1 II System Logo
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
