Question about Kenmore Heating & Cooling
Kenmore 580.75151500 A/C unit smells... We've had this window unit in place for 2 years. We've cleaned the front filter and coil, but we're still getting different, peculiar smells from the A/C. Sometimes it's vingar, sometimes urine-like, sometimes moldy smelling. Is there some place else that we can clean it? I've downloaded the user manual, but it's really just a parts manual - doesn't say anything about maintenance or upkeep. Thanks
    President:
  • 1,796 Answers
Hi!!
As you know, the evaporator unit (the one that the filter covers) gets a lot of condensation which is drained thru the back (outside) of the unit. That's why the unit is installed a bit tilted to the back.
The factory drain hole is too small and gets plugged up easy, some units don't even have one, the water sits for long periods of time. bacteria grows and the smell starts.
Unplugg unit from electrical outlet.
Make sure the unit is tilted back a little.
Drill two 1/4" inch drain holes in the same back bottom corner and set a bucket to collect the dirty water that will come out while cleaning it.
Get a quart of air conditioning grill cleaner (the ecol-friendly, it is purple in color) mix it on a spray bottle with water on a 1:1 ratio.
Use masking tape and some plastic to cover electrical controls in front of unit.
Following application instruccions on bottle, carefully spray on evaporator and condenser, avoiding electrical controls. Rinse with pure water, 2 qts. minimum on each grill, let it drain for about one hour.
Uncover controls and connect unit to power outlet.
Run the fan-only for about 10 min. and then the compressor.
There are more professional ways to service the unit, but performing this simple steps will keep your unit in good shape.
Don't forget to rate this post!! Good Luck!!
Posted on Jul 20, 2010
Have haier HWRO5XCM air conditioner. Outside temp is 75 degrees and I have set on 76. Freezes up and spits ices and water. Help
Clean indoor filter , and coils in unit (you must remove from window and remove top from unit to expose coil, After cleaning coils prop up unit so it slopes to rear and spray back and forth at bottom of front coil until drain is clear . Never turn unit upside down , and do not get water inside of fan motor . Also clean evaporator blower wheel . With unit clean and drained out place in direct sunlight for at least 2 hours to completely dry before replacing top and reinstalling in window , or just drain out , reinstall and leave unit unplugged for at least 24 hours to dry before testing . If unit is clean and still icing , check to see if thermostat works (place object in front of unit to direct cold air from top of unit onto thermostat temperature sensor and compressor should cycle off, if not replace thermostat . If unit still ices you will need a pro to repair sealed system of unit or simply buy a new one .
Thanks,
Alex
Oct 03, 2014 | Heating & Cooling
Why is there a ***** smell?
I worked extensively on GE Zoneline AZ Air Conditioners and Heat Pumps while a Maintenance Superintendent at a Senior Citizen's Apartment Complex. Not knowing what type of smell to which you are referring, I can assure you that other than "burnt electrical" smells, the only smell that could possibly be produced would be that from within the INDOOR SPACE. Perhaps something has made its way into the INDOOR AIR FILTER? Perhaps that INDOOR AIR FILTER needs to be cleaned. To clean the INDOOR AIR FILTER, simply lift both of the filters from the front cover, take to your clean bath tub. Run EXTREMELY HOT WATER from the back of the filter to the front of the filter. Then, fill your bathtub 1/4 way with EXTREMELY HOT WATER. Add 1 cup of Hydrogen Peroxide and 1 cup of Real Lemon Juice. Set both filters in this solution for 30 minutes; then rinse with clear water. Set filters up to dry for at least 2 hours in the sun or an air breeze. Replace filters into the GE Zoneline.
Also, not knowing how OLD your GE Zoneline system is, the COILS may need to be cleaned. To do this, simply turn OFF your GE Zoneline unit and remove the front COVER of the unit. Next, mix in a spray bottle 4 packets of LEMON flavored KOOL-AID (without SUGAR) and water. Shake well. Spray the INDOOR COILS of your GE Zoneline unit with the entire contents of this mixture. Let set for at least 10 minutes. Then turn your GE Zoneline to the COOL position. The citric acid in the lemon kool-aid will be forced through the coils to continue to remove any dirt, dust, debris and effectively CLEAN those coils. This will also provide you a LEMONLY odor within your room. Simple and cheap.
Enjoy your GE Zoneline unit.
Aug 30, 2014 | GE Zoneline AZ55H07D Air Conditioner
It is three and a half years old and ices up even at warm temps.
The problem you're having is generally caused by the air intake filter needing to be removed and cleaned and/or the cooling coils need to be cleaned.
I assume you already know how to remove and clean the filter, since you've had the unit for 3 1/2 years, so I won't bore you by addressing that.
The coils can be cleaned with warm water and a mild dish washing detergent using a sponge or rag. Once they have been wiped down, rinsed and dried, apply a light coating of WD40 to the coils.
Hope this helped you & thanks for choosing FixYa.
Sep 19, 2011 | Kenmore 54701 Dehumidifier
Hi. My 2 year old Friedrich CP10E10 window unit is not cooling the room like it should/like it has. I followed obvious troubleshooting steps per the operation guide, including thoroughly cleaning filter....
Check the OUTDOOR coil... it sounds like it is clogged up and the system is cutting out on high pressure...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 23, 2011 | Friedrich CP10E10 Thru-Wall/Window Air...
Machine sometimes makes a clicking sound. Removed front grill today and filter is very dusty and is stuck to the back. Replace filter or can it be cleaned? Other recommendations for servicing? We have...
1. Change the filter
2.Clean the "Condenser" (Outside Coil on Window Unit)
use a "foaming" spray then rinse with a garden hose.
3. Lube motor
4. Clean "Evaporator " (Inside coil) "foaming" type cleaner. Rinse with water in a spray type bottle.
Jul 10, 2011 | Heating & Cooling
Hello! I'm having some difficulty finding the drainage on this specific model. It's in my husband and I's bedroom....for the last two mornings we have found a puddle on the floor in front of...
Water leakages out the front are usually attributed to poor drainage. IE , the wall unit is not sloping slightly to the rear, or in the case of a split system, the drain hose is not directed down and away from inside. I would suggets checking the filters first. If the filters are blocked, and the cooling is set really low, its possible for the coil to start freezing and thus, leak water out the front. If the filters are clean and the coil is still freezing, you may have a gas shortage . Eventually when the gas runs out, the water leak will stop and the unit wont cool at all. If the system is working properly, on cooling mode, there should be cold air inside and the unit should be blowing hot air outside. If on heating mode, the reverse happens...
Jun 14, 2011 | General Electric AST05LK Thru-Wall/Window...
Washer has ordor
run a cycle with a heathy amount of bleach on hot. Odor is usually due to bacteria or somehting left behind. Is there any filter that can be cleaned??
Jer
Jan 16, 2010 | Kenmore HE2 Plus Front Load Washer
Thank you. I have an 11 year old Kenmore 8000 BTU window unit that has served me well. I am remodeling my apartment now and would like to have a service and maintenance check on this unit that might...
take it to a hvac shop and tell them what you want! or just telll an electrical shop what you want in the cord length---to straighten out the fins n the front coils with a fin coil brush at a hvac supply house,and remove the top/ side cover and fully clean the inside unit, drain lines--both front and back coils---on both sidesan oil the fan motor....TYVM!
Dec 03, 2009 | Kenmore 8000 BTU Single Room Air...
Heating & Cooling Logo
620 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
