Question about Microsoft Xbox 360 Controller
My wired xbox 360 controller keeps disconeting from my computer and reconnecting every 3 seconds
  • 3 Answers
I have the same problem. If you have ever dropped it on the ground multiple times then that could be it. That or there may be faulty wiring. I would recommend checking the warranty (if you have it?). Other than that you should buy a new, by new I mean used, off of eBay for possibly dirt cheap.
Posted on Aug 11, 2010
Walmart controller not working on my pc
Set up a wired controller
Step 1: Install the Xbox 360 controller for Windows software
Use the installation CD that came with your Xbox 360 controller for Windows before you connect the controller for Windows to your computer:
  1. Insert the installation disc in the CD or DVD drive of your computer. If the Setup program does not automatically start, change to your CD or DVD drive and run the setup program.
  2. On the setup screen, click Install.
  3. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
If you don't have an installation disc for your Xbox 360 controller for Windows, you can download and install the software online:
  1. Go to the Software Downloads section of the Microsoft Hardware website.
  2. Select Gaming as the product type.
  3. Select Xbox 360 Controller for Windows as the product.
  4. Select the version of Microsoft Windows you are using on your computer, select your operating system language, and then click Download.
  5. Click Run.
  6. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
Step 2: Connect the controller to your computer
After you install the software, plug your Xbox 360 wired controller's USB connector into a USB 2.0 port on your computer.
Step 3: Test the controller
To test your Xbox 360 wired controller on your computer, follow these steps:
  1. On your computer, click Start, type Run, type joy.cpl, and then press ENTER.
  2. Select Xbox 360 Controller, and then click Properties.
  3. Test your Xbox 360 wired controller by pressing a button, pulling a trigger, or moving a stick on the controller. If the controller is functioning correctly, you will see the corresponding action light up in the application. If the application does not recognize your controller, see Troubleshoot your Xbox 360 controller for Windows.
Jan 06, 2014 | Microsoft Xbox 360 Controller
Ho w to fix x box from controller to x box is really slow how to make it normal
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
Sep 29, 2011 | Microsoft Xbox 360 Console
I have a wireless xbox 360 controller and it will work for awhile with my new xbox 360 slim. then the controller will shut off and it will say Please Reconnect the Controller. i do and 3 minutes it will do...
well its pretty much easy to tell that you got ripped off because duda your xbox is brocken now so i would return it and get your money back then buy a new one
Aug 23, 2010 | Microsoft Xbox 360 Controller
My controller just shows all four lights flashing and when i try to sync it, the lights just keep spinning round and does'nt connect
The wired and wireless controllers can be actively connected to an Xbox 360 console all at one time. Each connected controller is assigned a quadrant on the Ring of Light. Before you can connect a wireless controller, at least one quadrant must be free and will be unlit.
Connecting an Xbox 360 Wireless Controller to an Xbox 360 Console is called Connecting. To connect a controller to a console:
First, Press and hold down the Guide Button on the wireless controller until it turns on.
Second, Press and release the power button to turn the console on.
Third, Press and release the connect button on the console.
Fourth, Press and release the connect button on the controller.
Fifth, After the ring of light on the controller and console spin and flash once, the controller is connected. The quadrant that remains lit indicates the controller's position.
Four Green lights on the controller's Ring of Light flash continuously
The Please Reconnect Controller message appears on the monitor
There is interference and the controller does not respond properly
Step 1: Ensure that either the AA batteries are new or the Xbox 360 Rechargeable Battery Pack has a full charge.
Step 2: Ensure that you have performed the proper procedure to connect the Xbox 360 Wireless Controller to the console.
Step 3: If still experiencing issues, ensure there is a clear line of sight between the front of the console and the wireless controller. If there are any obstructions, especially metal objects, remove them.
Step 4: 2.4 gigahertz cordless telephones, microwave ovens, and Bluetooth headsets for cell phones can interfere with the operation of the wireless controller. Turn off or unplug those devices and then try to connect the wireless controller to the console again.
Step 5: If these steps did not resolve the issue, the wireless controller may need to be replaced.
Jun 03, 2010 | Microsoft Xbox 360 Controller
My xbox 360 will not allow the controllers to stay connected, it keeps making me reconnect the controllers about every 30 seconds, Got any suggestions?
what i would say is that you should your batteries are bad, either that or you need to make sure that you have the same controllers that came with the system or if not to make sure you synch them with the console
Feb 28, 2010 | Microsoft Xbox 360 Console
My rock band guitar doesnt connect
if the things wireless hit the reconnect button on the guitar and console at the same time for a few seconds
Dec 15, 2009 | MTV Games Rock Band Bundle for Xbox 360
I put it in a game and it says open tray again
you xbox needs cleaning on the inside proberbly the lens try and get a cleaing kit for it
Jun 06, 2009 | Microsoft Xbox 360 Console
Xbox 360 wireless controller not connecting.
it sounds like your controller keeps losing sync with the 360.
- turn them both off
- turn on the 360 with the power button on the console
- wait for it to start up, then press the sync button next to the usb flap on front.
- then press the sync button on the controller (by the recharge connection slot)
That should reset it.
Nov 13, 2008 | Microsoft Xbox 360 Wireless Controller
Microsoft Xbox 360 Controller Logo
185 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
