Question about Maytag Neptune MAH5500B Front Load Washer
Stopped with a load and water displayed a code of nd
    President:
  • 1,382 Answers
When error code "nd " flashes remove water pump, check for thongs, baby socks and sometimes hair pins or even screws can obstruct the water pump.
Simply remove the pump and remove the obstruction that is keeping it from draining. This will fix your problem.
Thank you !!
Posted on Jul 20, 2010
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: won't finish cycle, water still in tub, code nd
check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on Jun 19, 2009
App King
  • 55 Answers
SOURCE: Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Posted on Jul 15, 2009
Washer machine shows "ND" and doesnt got in to spin cycles or drain water out
The most likely cause for your issue is excess debris in the pump strainer, or a bad impeller on the pump. If you have a front small trap door on the front left or right, follow the instructions in your manual for cleaning out the trap. If the trap is empty, or does not exist on the exterior, you may need an experienced repair man to open the machine up to get to the pump strainer and check the drain pump. Pleazer Appliance...
Apr 17, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Code on MAH9700 display is ND- clothes are sitting in water.
ND code means 'No Drain' and it is probably just something caught in the pump. I've seen where a coin can get in there and keep the pump from starting.
Some other items known to stop a Neptune pump: rubber backing from a rug, rubber bands, bobbie pin, lens from a flashlight, tooth pick and a bra wire. Maybe you had something different in your pump? If so, please comment with what you discovered in your pump.
If you have a floor drain you should be able to drop the discharge hose to the floor and let gravity pull the water out so you can take the pump out and get a good look at it.
Also a word of advice to avoid wasting time. The pump is usually towards the front of the machine.
Hope this helps.
Jun 03, 2011 | Maytag Neptune MAH9700 Front Load Washer
My washing machine is displaying the letters "nd",
ND is no drain error code for the FAV6800A and most Maytag machines.
Is there water in the Wash Basket. If not this could be a stuck Pressure Switch. If there is water in the Wash Basket then there could be a Drain Pump issue/Drain Line clog.
If you want to DIY I can help you.
Feb 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Someone put some heavy things in it and it stopped mid-cycle. We removed the heavy objects, and then attempted to drain the leftover water by putting it on "rinse and spin." It never really...
The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
Nov 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer stops before the rinse cycle because it can't seem to drain enough to start the spin cycle. I just had the drain motor replaced one month ago. I get the error code nd. I can sto the cycle and...
I'd love to say yes! The machine is stopping because it will not drain. This is what the nd code means. Therefore, it will not rinse (add more water) or spin because the water level is already too high and to try to "spin it out" would put too much pressure on the machine with that much water in it. Drain out the water by putting the drain hose below the level of the washer (this takes forever) and call your repair man back!
Feb 18, 2010 | Maytag MAH8700A Front Load Washer
Hello.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytag washer gives code "nd" and stops! What is the problem??
"nd" is code for "difficult draining" installed a new water pump $60, problem solved.
May 11, 2009 | Maytag MAH8700A Front Load Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Washer will not spin; displays nd error
(nd) stands for no drain check the pump,and drain hose
for clogs
Dec 24, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
294 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
