Question about Kenmore 43142 Front Load Washer
My Kenmore front load tumble action washer model number 417 is stopping mid cycle at the after rinse and won?t go to final spin automatically. Also it won?t draw any cold water into the machine an only draws water in if the machine is on warm or hot (on warm it is only drawing in Hot water. We then push to stop and turn the control to a point in the spin cycle where it will finish.
  • 4,070 Answers
The water temp problem is because your cold water inlet valve is not opening. It's a dual water inlet valve and the whole thing has to be replaced. It's located where the water hose is connected to the dryer.
The final spin problem is probably caused by the control which is not making contact when it gets to that spot in the cycle. I have had luck taking the control apart and cleaning the contacts.
Posted on Jul 20, 2010
  • johndeely Jul 20, 2010
    I have checked the valve and confirmed that the cold supply is working
    did you mean the valve is inside the washer and that you are not refering to the valve supply in the wall?
My washer won't spin when its on rinse cycle
What is the complete model number of your unit?
Dec 05, 2012 | Kenmore 43142 Front Load Washer
The washing cycle stops at the final spin. The
If this machine is a Kenmore 417 Sourse (WCI) built washer with a font load,check tech sheet.I had the same problem on a Frigidaire frontload and it was the door latch/lock assembly.These machines can be tricky sometimes.Use tech sheet and make sure lock assembly ohms out ok.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Will not spin or drain
take front panel off in the water pump rubber hose feel to see u can feelsomething in side the pump .this will cause the pump to stop/and not spin
May 12, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Snaggs, If your model number begins with 417 it could be a couple of issues. Start with the drain pump. Remove the bottom panel and see if the pump is clogged with coins or debris. It will be on the right. Check the pump impeller. Have a bunch of towells handy as you will have a lot of water coming out at you. When you drop the bottom panel you will be able to see if the belt is on in back. If this does not clear up the problem, more than likley it will be in the motor control board. Catriver...post back.
Sep 23, 2006 | Kenmore 43142 Front Load Washer
Kenmore 43142 Front Load Washer Logo
171 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
