Question about Microwave Ovens
Microwave shuts off about 10 - 30 after starting to heat an item. Display flashes PF. Which I figure is power failure. Unit is 5 months old and has very little use. Model WES1130DM1WW purchased at Wal-Mart.
  • mr_garyPPL Sep 13, 2008
    I have the same model only I don't get any power at all. Even the display won't light up. Is there a user replaceable fuse?
  • Microwave Ovens Master
  • 9,098 Answers
It should have a one year warranty, right? If so, Westinghouse should take care of it for you.
Contact Westinghouse Small Kitchen Appliances at 800-245-0600 or 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 23, 2008
GE microwave with error code of PF and won't heat anything up
The "PF" on any appliance indicates a power failure. So if you lost power in a recent storm, this would cause your problem. Pressing the cancel button should clear up your problem, and put you back in business. If not, unplug the unit, plug it back in and try the cancel button again. If trouble persists, your board is probably at fault.
Jul 20, 2014 | GE Microwave Ovens
Model 85610 shut off and won't turn back on
  • Magnetron failure
  • Door interlock failure
  • Control board failure
  • Internal fuse failure
Jul 22, 2017 | Kenmore Microwave Ovens
Powers off immediately after starting
My immediate reaction would be to cut your losses and buy a new unit as sooner or later you will run into a part that is no longer available.
Nov 03, 2012 | Whirlpool Microwave Ovens
Power failure on ge wes1130
Power being interuppted could be anything from a bad fuse , bad fuse holder, bad solder connections on the main board. Bad breaker in your panel. Start by plugging it into an outlet you know is on a different breaker than the on it is on now. See if it does the same thing. If it works ok, then problem with power to the other outlet. If it does the same thing problem inside of unit. PF is Power Failure, now we have to figure out why.
Oct 15, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Not heating digital display says
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 11, 2010 | Maytag MMV1153A Microwave Oven
I have a Kenmore over-the-stove microwave oven that is not heating food. Everything else works. I received a message of PF on the keypad. Is there anything I can do before I have to call a repair...
PF - Power Failure - PF error code indicates a power failure during the cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 13, 2010 | Kenmore 62702 Microwave Oven
Sylvania microwave convection oven overheats after
you need to remove the cover and after it operates and shuts down(CAREFULLY) feel the magnetron tube sides (BE EXTREMELY CAREFUL<HI_VOLTAGE ON TUBE FROM CAPACITOR) still, then if its not too warm there is a small temp sensor held by 2 screws on the side of the tube and they can go bad and shut off current to the tube,the tube will run warm, but should never run HOT,if its hot its defective
Oct 28, 2009 | Sharp R-353 Microwave Oven
At least twice in the past month have had food explode all over the microwave (as if it was overheating). Items vented properly or not covered at all. this time, kept making poppong noises for at lesat 10...
If you have an item overheating, try looking at the directions on the unit for the watts and adjust cooking time according to the oven. Some foods will explode if left for too long in a quick heating microwave oven. If this is a new problem and the microwave is 4 years old, you may consider the unit is beyond its useful life. Its difficult to tell w/o knowing the brand, but it could be the meagtron tube is simply wearing/worn out. Let me know if this helps. m
Oct 20, 2009 | Sharp R-428J 1200 Watts Microwave Oven
Microwave lost power in the middle of heating a lunch. Later power came on with PF in the display. Is this normal?
it seems the thetmal cutoff(TCO) mounted on the magnetron to protect it from overheating is going off.it opens out when magnetron overheats and cuts the power to the control board and after the magnetron cools down tco resets and power to control board is restored with the sign PF(power failure).the fan that cools the magnetron may have gone bad.i think u will need a tech 2 chk it out.
Aug 17, 2009 | Hotpoint RVM1625 Microwave Oven
Microwave Ovens Logo
270 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
