The water is not flowing when I start my machine
  • 6,784 Answers
Hi this will usually be the result of a failed inlet assembly. Use the procedure below to isolate the culprit.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Next; Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.
There are two wires connected to each solenoid on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals ( Be sure to not pull the wires). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. Test the second one in the same way as the first.
Posted on Jul 20, 2010
  • 4,070 Answers
See if you hear the buzzing of the water inlet valve when you turn it on. It's at the back where the water connects to the washer. If you hear it then it's not opening and needs to be replaced. Be sure to try cold and hot. One of the valves may work.
It you don't hear it your pressure switch could be bad. Your pressure switch stops and allows it to start the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water.
The lid safety switch can be bad. You can bypass it by connecting the two wires to it and seeing if it works.
Hello. my Lavamat 74500 update does not start the wash cycle. everythig is on, door locks but nothing happens.
sounds like a water fill problem to me, normally at start of cycle door locked, program set, start water solenoid opens and fills machine with water, once water reaches set level heater will come on and wash program will commence,
so if you have a restriction in the water supply/ water tap not turned on correctly, on blockage in water solenoid valve water flow to machine will be restricted causing a long delay before machine starts, things to try
1. make sure hose connection water valve is fully open
2.open soap draw to see / if you can hear water flowing into machine,
3 if its very slow you have a restriction in water supply
could be a twist in water supply hose, causing a restriction
all above is if machine is taking to long to fill with water,
good luck .
Oct 05, 2016 | Washing Machines
When i turn on the washer it won't start& water keeps flowing into washing machine. does the water flows or not suppose to flow into the washing machine from the inlet valve?
water into a washing machine is controlled by a tube in the side of the bowl up to a pressure switch
as the water level rises in the bowl, pressure in the switch is built up until it overcomes the setting that you have made for a water level on the wash size selection switch
at this point it turns off the inlet solenoid switch and starts the wash cycle
If the water solenoid is burnt out then water will continue to come in and over flow the bowl but it should be washing as well
If the water is not stopping then check for a disconnected hose to the switch or ma hose full of water
failing all that get a washing machine mechanic in
Apr 18, 2015 | Maytag Neptune MAH5500B Front Load Washer
Hot water will not stop flowing. Hot water
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
Sep 18, 2017 | Bosch Axxis WFL 2060 Front Load Washer
I have Beco WM616 7W washing machine...when I start washing...water should filled in washing machine but it comes out from somewere..all programms working...just water comes from bottom..
Check all your hose connections. Sounds as if the drain hose has come loose or burst. (common fault in all machines).
Open soap drawer, and check that water is flowing into it.
If no water is flowing into it, looks like the water connection hose at rear is not secure.
If water is flowing into the drawer, but not staying in the drum, then check the drainage outlet hose is secure and undamaged.
Jan 21, 2013 | Washing Machines
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Solis Palazzo - dreaded ventilate problem
Hi
Your machine is still in the descale mode. You haven't finished. If you have run the descaler through, the water is ermpty the pump will still keep going until it stop on its own. If it doesn't stop on its own, the computer thinks its still in the descale mode. remove the water tank and turn the machine back on. The pump will run and then make a lot of noise, then stop. This can take up to 5 minutes. Let it run until it stops. You will get blinking lights on the panel. Put the water tank back on and close the steam knob then open it again. The pump will start the rinse mode. Let it stop on its own. Computer can't see that you ran a whole tank of water, but it can see when the flow meter stops that there is no water left. If you have already rinsed the machine start the pump flowing and just lift the tank off. When the pumps stops the rinse cycle the descale light will be gone but you will have the heater light blinking and the water light steady. Put the tank back on and close the steam valve then open it again. This will clear the water light and the machine will start to heat again.
Apr 15, 2009 | Saeco Incanto Classic Espresso Machine
Problem
Lets start on the simple things...
1. All hose connections are in place and connected to the washing machine.
2. All valves supplying water to the machine are in the open position (ie: if the hoses were removed from the back of the machine, water would be flowing)
3. The machine is plugged in and otherwise operating.
If this is an older machine nd it used to work then I'd check to see that the flow valve (kind of like a relay that allows water to enter the machine) is functioning properly. Do you hear it click when water is supposed to be entering the machine? If not, it might be bad. Consider also trying to change the water selection switch on the machine to a different setting. If water starts to flow, look at one of the flow valves.
If this is a newer machine and it has never worked, review the 3 items above. If all seems to be OK and it still does not work, get in touch with the company you purchased from and exercise your warantee rights.
let me know what happens. Please rate accordingly.
May 29, 2008 | Whirlpool Washing Machines
ICE CUBE WATER FLOW IS LOW
This is a Manitowoc model QY0214A. The water tough starts to slush up after about 3 minutes after start up cycle. The slush prevents water from flowing to the pump for circulation.
What can be wrong?
By
Greg
May 27, 2008 | Dishwashers
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Increasing water flow rate
Back-flush the machine regularly and check your water hookup and make sure you to not have a small diameter water line. Other than that it is controlled by the water pump I believe. If the solenoid (the silver thing attached to the pump) used to start the pump is old it could slow down the pump start cycle.
Jul 01, 2007 | Rancilio S24 Espresso Machine
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
