Re: Canon imageCLASS mpc 190 Perfect machine for last year or two. Just flashing message 'WAST INK NEAR FULL'. Basic Guide not a a help. 'CHECK PRINTER' does not appear. Can I fix myself, or over-ride message without harm to the machine? philkelso@bigpond.com in Australia. (.au not needed)
  • philkelso Apr 21, 2008
    instructions ok as far as 'Press SET key'
    Don't seem to have one.
    Phil
    Thanks,
    I switched off and restarted - to go through the process again - and everything seems OK. Thanks for help. I still don't know why the message came up, it would be natural to assume the waste tank is full, if message reads 'waste tank is full'. Silly me. I just hope I don't get an overflow.
    Regards
    Phil
    Master:
  • 555 Answers
See this page for instructions on resetting your waste ink counter.
Posted on Apr 21, 2008
  • Matt Jurach
    Matt Jurach Apr 21, 2008
    The steps for your model are as follows:
    • Enter SERVICE MODE -- By pressing Menu, Copy, Scan, Copy, Copy
    • Select TEST MODE.
    • Select 8 PRINTER TEST in TEST MODE.
    • Select 3. [EEPROM CLEAR].
    • Select 0. [INK COUNT].
    • Press the Set key.
    • Press the Stop/Reset key (returning to the state of 3), and then press the ON/OFF key.
  • Matt Jurach
    I'm looking everywhere, but I can't find a picture of your printer's control panel so I can look for the corresponding key!
    On HP printers, the "Set" key is a green key with a check mark on it.
    Perhaps your Canon has a similar key that is used to "enter" whatever menu item is selected?
How to solve error 6C10
You cannot solve it by yourself.
This error means, that the wast ink absorber is full and needs to be replaced. When a new waste ink absorber has been installed, the device needs a reset. This can only be done by Canon service.
May 20, 2013 | Canon Pixma Mg5250 Imageclass Inkjet Scan...
Wast ink absurber full..error27
Hi
The wast ink absorber full, if you want to clean the ink absorber at home without wast money, i will provide you the example in Canon printer,how clean you ink absorber follow the mention below instruction and remove the error of ink absorber.
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
God Luck
Sep 05, 2011 | Canon PIXMA iP1000
Message CHECK 5100!!!
hi; this message appears when the wast ink absorber is full
Oct 14, 2010 | Canon FAX-JX200
I have a Canon PIXMA iP400 - it refers to the
My printer is still giving me great pages and pictures but I am now getting this same message about wast ink absorber being nearly full solutions please.
Nov 10, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
The ink absorber is full
plese it is problem your printer is not print because some of ink is full printer wast tank clean it and reset press printer resum button two times
if you are not success then you go to in your area service authorised delar
Aug 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
If ink absorber is already full what should i do next?
it is not possible for you it is the problem mantainence wast tank full it mean when we print then chack cartridge is automacily clean then some ink fall under pad this pad is full ink then machine say ink absorber tank is full
you go to aservice centre only support printer canon. Thy clean wast tank and reset your printer
Jul 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Screen says waste ink near full
These are pads located directly below the cartridges while in it's resting position.These pads can be removed with tweezers and cleaned with any ink removing cleaner and then with warm water and soap,Dried and replaced.
Apr 05, 2009 | Canon Office Equipment & Supplies
Waste ink near full
This page gave me a solution worked for me: http://www.inkjethelper.com/inkjetstuff11.html
Mar 23, 2009 | HP LP LPQ1200 Matrix Printer
Canon MPC 190 Imageglass printer
Hi, taken from here: http://www.fixyourownprinter.com/forums/printer/27470
1. Press MENU COPY SCAN COPY COPY
2. This will take you to TEST MODE
3. Use the + key to take you through to PRINTER TEST (option 8)(if you go past, either keep keying the +, or you can use the - to take you back)
4. Ensure that it shows 8-3 on the screen. This is EEPROM CLEAR
5. Press OK
6. It will show 0 INK COUNT
7. Press OK
8. Press the STOP/RESET button
9. Press the ON/OFF button
10. The printer won't turn off, but will "reset" itself (or something).
I'm not sure what this does, but it gets rid of the "WASTE INK NEAR FULL" message and you should be able to print again with no problem.
Feb 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon mpc 190 waste ink near Full
not a user issue to have repaired. Need to call service person.
Jul 09, 2007 | Canon SmartBase MPC400 All-In-One InkJet...
77 people viewed this question
jasbo
jasbo
