Question about Maytag MZD2766GES Side by Side Refrigerator
The freezer ices up. I have an MSD2758DRW side by side.
  • 4,070 Answers
DEFROST PROBLEM The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad. With an ohm meter it should show continuity when cold and none when warm. You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Part 13 on this diagram is your control http://www.partselect.com/ModelFrames.aspx?ModelID=137452&ModelNum=MSD2758DRW&mfgModelNum=&ManufactureID=1&Selected=52951&Position=1&mfg=Maytag&Type=&Mark=1
Posted on Jul 20, 2010
Water dispenser does not shut off
That is most likely a dual water control valve stuck open on back of refrigerator near floor. One side feeds ice maker and other side feeds the water dispenser. If the ice maker side began to leak slowly it would create quite a mess of ice flowing over ice maker and freeze every place it could inside the freezer. Part and Model Search If helpful Please Rate this solution, Thank You, Sea Breeze
sea_breeze_260.jpg Refrigerators
Freezers
Washers and Dryers
Oct 18, 2011 | Frigidaire Refrigerators
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
Does not dispense ice. Ice tray in freezer is
your haveing air cirrculation problems due to to much stuff in your freezer or fan itself isnt pushing enough air
Apr 19, 2010 | GE Profile PSS26MGS Side by Side...
8 yr old maytag msd2758drw side by side isn't freezing
If the clicking noise is comming from the rear of the frig it could be your compressor trying to start. The motor would be the fan in the freezer running. That part would be normal.
If it is the compressor it could be replaced but if it were me I would buy a new frig.
Dec 29, 2009 | Refrigerators
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Maytag MSD2758DRW freezer frosted over
Yes you have eather a bad defrost timer, defrost heater, or the drainline could be stoped up. Call a some real Ref. tec people because those don't know what they are doing.
Aug 04, 2009 | Maytag MSD2650H Side by Side Refrigerator
Whirlpool side by side (106.56692501). Refrig was not cooling but freezer is. Freezer is slowly heating up though. Unit is still running. It just isn't blowing air into the refrigerator.
You have ice in freezer fins. You need to remove back panel inside of freezer, melt all the ice replace panel, plug refridge back in. The ice causes bad airflow to the refridge side, causing to heat up.
Jul 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer not cold enough/ice maker not working
Check the coils in the freezer to see if they are blocked with ice.
May 01, 2009 | Frigidaire 11.6 cu. ft. / 328 liter...
Snows inside freezeer compartment of side by side
You actually have 2 problems here.
One the ice maker shutoff is defective. REPAIR is to replace the ice maker.
Two (snow) is a loose door seal, Outside air entering the freezer.
Feb 20, 2009 | Kenmore Refrigerators
Ice on the back wall of the side-by-side freezer and no ice
Possible circulation fan has quit, or defrost element is not working, call service.
Apr 20, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
268 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
