Gas dryer starts and runs but does not heat.
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
Sep 13, 2014 | GE Profile Gas Dryer Model Dpsb513gb0ww
Dec 17, 2013 | GE DCVH515GF Gas Dryer
Jul 19, 2011 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
Oct 07, 2010 | GE DBXR463EDWW Electric Dryer
Jul 19, 2010 | GE DCVH515EF Electric Dryer
May 29, 2010 | GE Profile Harmony DPGT750EC Electric...
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
Apr 16, 2009 | GE DBXR463GB Gas Dryer
Mar 09, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
May 15, 2008 | Whirlpool LGR7646E Dryer
357 people viewed this question
RUNS BUT NO HEAT
my ge gas dyer pilot must have went out. it turns on but doesn;t ignite. it's a basic dryer and a year old. can you help. model #DBXR463GD3WW
thanks so much
My gas dryer tumbles, but does not heat.
