Question about Logitech QuickCam Communicate STX Personal Web Camera
The picture is just very bury and unclear how do i fix it?
When i view with the cam the picture is very bury and unclear... i tried the focus it didn't help a bit. i even uninstalled the drivers and reinstalled it but nothing change... please tell me how to fix it
the picture is blurry and the frame \rate seems to bee slow and also an unrelated problem the effects other than fun filters arent working
  • 1 more comment
  • Anonymous Nov 02, 2008
    i have the same problem, looks like no one knows t
  • Anonymous Nov 30, 2008
    The picture of my cam is grainy and very unclear! I dont think it can be fxed..
  • tpratt3043 Dec 14, 2008
    I have the same problem now but I didn't 3 days ago when I bought the thing, it's so frustrating!!!
  • Logitech Master
  • 13,433 Answers
Clean the lens, well it might be that your camera is faulty.
Posted on Apr 22, 2008
Out of focus pictures when shot with view finder
I had a problem similar to this. Try taking off your glasses or removing your contacts and try again. Best of luck.
Nov 23, 2013 | Canon EOS 60D Digital Camera with 18135mm...
HP VGA Webcam problem.
If you go to the front of the webcam, their is the camera surrounded by a dial. Turn the dial until the picture comes in clearly, and when you get it perfect, don't touch it. Just leave it the way it is and your all set. Hope this Helped -CA
Jul 14, 2008 | HP VGA Webcam
When I turn my RCA F32672SB on the picture is clear for awhile than it becomes unclear and hard to view. I turn it off and back on again and the picture is unclear and after turning if on and off several...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is ...display becomes blur .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT ( same type ) should be replaced.........100% it works normally
May 21, 2011 | RCA F32672SB 32" TV
When I take a picture with the Canon Rebel, it doesn't focus in the view finder, but when I look at the picture after it has been taken, it is clear and in focus. Why can't it looked focused when looking...
Good day,
The problem you might be having is that the view finder is out of focus.
If this is the problem it is an easy fix.
You will see a small wheel next to the view finder (it has a + and a - next to it), look through the view finder and let the camera focus on an object. Now turn the wheel and you will see the image either get worse or start to come in focus. Adjust the wheel until you are satisfied with the clarity.
Please let me know if this was helpful!
Regards
Nov 29, 2010 | Canon EOS Rebel XSi Digital Camera
The auto focus is not working. My pictures are blurry & out of focus.
Clean the contacts on the camera body and the lens where they meet with a cotton swab dampened lightly with rubbing alcohol.
Aug 17, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
I'm not sure what settings are best? Mine come out blurred now..say for automatatic settings? Thanks
Set jog dial on auto (green mark), clean front lens of camera and check for clear and in focus view.
Still unclear picture then lens got bad and need qualified tech to fix it.
Aug 03, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
Video picture is not clear on webcam. Picture is not focused. How do I correct the blurred image seen by the webcam?
Most web cams have a short focal range, (Nearest to furthest focused content), and have a front lens that turns like a dial so you can choose where you want your camera to focus.
Try Twisiting the housing or ring around the front lens, if it turns then turn it while viewing the image on the computer to set the focus where you like.
Also make shure there are NO smudges on the lens, it's small so even the tinyest smudge or spec is huge on the screen.
Jun 18, 2009 | Philips SPC230NC Webcam
Acer 5520 webcam is really blurry now and wasnt before.
go on line with a friend with your cam on, go into the cam settings and adjust the focus or contrast, ask your friend if there is a difference in picture, if this is the case adjust it until your friend says its ok, if it doesn't work clean the lens and try re-installing the drivers by putting the cam in a different USB port
Nov 14, 2008 | Acer Aspire 5520-5908 Notebook
Pictures unclear
1. Indoor photographs will not come out well unless there is good lighting in the room.
2. This camera has very old technology and is very cheap. It does not have auto focus. It can only focus to two positions: Macro for less that 6 feet and Distant for everything else. Use the focus ring at the front to switch between these two positions.
3. The camera is very slow in recording the image so you must hold it very steady while it takes the shot.
Good luck.
May 06, 2008 | Aiptek Mini PenCam Digital Camera
Hello desigurl and Leota,
THIS article from the Logitech website should prove useful..Also make sure you have the latest driver for your camera. Click HERE to find out which is the correct version of QuickCam software for your camera.
Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Enjoy free holidays, meals, haircuts and more, with mystery shopping!! USA / UK
FREE SOFTWARE GIVEAWAY
Windows Utilities
Apr 10, 2008 | Logitech QuickCam Chat Personal Web Camera
Logitech QuickCam Communicate STX Personal Web Camera Logo
357 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
