Question about Kirby G4 Bagged Upright Vacuum
REPLACING THE KIRBY POWER SWITCH
Here is a guide to replacing the power switch on your Kirby...
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope it helps!!!
Marci
  • Anonymous Nov 27, 2008
    i plug in my kirby but it will not turn on
  • Anonymous Jan 03, 2009
    replaced cord and it worked for a few months. Now it wont turn on.
3 Suggested Answers
mc1bean
  • 3053 Answers
SOURCE: carpet shampoo directions....
Hello, marci
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my own personal time
to see if I can help. Even though this a Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about vacuum cleaners and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/vacuum-cleaner.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just tried to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry.I do not get paid to help people on the site, I do it cause I like to help.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 30, 2011
Arius
  • 446 Answers
SOURCE: how do you install the belt on the kirby vacuum
Step 1:
UNPLUG YOUR KIRBY VACUUM CLEANER. Before you go any further, take your time with this belt change. It's not that difficult, just a little different than most other vacuums. These belts are very easy to find on the internet. kirby-oldstyle1.jpg Step 2:
You should be facing the front of your Kirby vacuum. The height adjustment lever will be on your right. Push the lever all the way down. Lift the light hood with your left hand. Turn theKirby vacuum belt lifter counter-clockwise with your right hand. Unlock the accessory lock. The accessory lock is located under the light hood. Move the lock to the left to disengage it. Remove the front of the vacuum cleaner.
kirby-oldstyle2.jpg kirby-oldstyle2a.jpg Step 3:
Turn the vacuum belt lifter all the way clockwise until the belt drops down. Unlock the roller plate by releasing the two latches on the rear. Pull the roller plate up slightly and then off. kirby-oldstyle3.jpg kirby-oldstyle3a.jpg
Step 4:
Bend one end of the roller bracket just enough to remove the roller. Remove this end of the roller. If you need to replace the roller take it all the way out. Remove any carpet fiber, string, or hair from the roller with a scissor.
kirby-oldstyle4.jpg kirby-oldstyle4a.jpg Step 5:
After you have removed the old belt, slide the new one back on the middle of the roller. If you're Kirby vacuum cleaner has a belt indicator light, the roller will have a magnet built onto one end of it. It's very important to install to install a roller with a magnet on the same side as the indicator light. The roller actually will only fit into the roller plate one way.
kirby-oldstyle4.jpg Step 6:
Place the roller back in the roller bracket. Place the roller bracket back and lock it into place with the 2 latches. Rotate the vacuum cleaner belt lifter counter-clockwise. You should feel the the belt catch. Look inside to make sure the belt is being stretched onto the vacuum belt lifter. Reassemble the machine. After you have reassembled your Kirby, turn the belt lifter cockwise, releasing the vacuum belt onto the vacuum motor shaft. kirby-oldstyle2.jpg
Posted on Nov 27, 2008
The foot switch does not turn on the G4D Kirby vacuum cleaner.
Here's a link to a free guide! The switch is available at this site as well...there is a link in the guide to buy one.
Hope this helps,
Marci
Aug 05, 2009 | Kirby G4 Bagged Upright Vacuum
Intemitant power
DO NOT TURN ON THE KIRBY ANYMORE UNTIL YOU GET THIS FIXED!!! (not even to show someone what it sounds like)
Your carbon brushes are worn out and will cause damage to the armature if you run the machine before they are replaced..
You can use my guide for replacing the power switch to break the Kirby down and allow you to get to the carbon brushes to replace them.
Hope this helps,
Marci
Jun 16, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby stopped working
Here is a guide to diagnosing a problem with your Kirby. I would imagine that your power cord has a short in it or the carbon brushes need replaced. You may want the take a look at my guide for replacing the power switch as well to make sure that it was hooked back up correctly.
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Hope this helps...
Marci
Jun 15, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby G5 vacuum
check the cord. see if there are any frays. or broken spots. usually it is one of 3 things. 1, faulty electric cord. 2. the attachment or floor nozzle not being properly attached( kind of a duh issue LOL)
3. a faulty switch assy. the switch can be kind of a bear to replace. I hope it is the cord. if not i would take it to a kirby repair person, because it is very easy to damage the motor assy when replacing a kirby switch. trust me i have damaged a few learning how to do it
Jun 21, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby ultimate g handle staying upright
Please see my online guide for replacing the power switch. It will get you into the case. Just use this link....
Hope this helps...
Marci
May 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
Jan 02, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
2,342 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
