Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Sony grand wega kdf 60wf655 will not start up. red light blinks three times. lamp replaced a year ago.
  • petersciacca Jul 20, 2010
    the red power light is blinking three times.
If the POWER/STANDBY indicator flashes three times, the lamp cover may not be attached securely. Review the lamp-changing instructions in your owner's manual, and make sure that the lamp cover is securely attached.
Posted on Aug 10, 2010
My sony kdf-60wf655 keeps shutting off on its own.what is the problem and can i fix it myself
If tv turns back on itself after shut down then it is weak lamp problem, replace lamp in tv to fix its problem.
Buy Sony original lamp for good picture in tv and replace it as it is user level repair and lamp replacement procedure is mentioned in related user manual.
If standby light start blinking after shut down, let me know how many times it blinks after three second pause to provide you info about possible cause of problem.
Thanks.
Dec 06, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a sony model kdf60wf655. i replaced my lamp nearly a year ago, but now i have black screen, no sound, and the lamp light is constantly flashing red. please advise how to fix.
Lamp light constantly blinking shows that lamp is dead/ broken. If any thing else like ballast supply etc become defective, standby light will start flashing in specific order.
Replace lamp and make sure to get Son original replacement lamp to solve the issue.
Thanks.
Oct 28, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
The standby light blinks green like its about to turn on then keeps blinking red and nothing turns on
A very common problem in Grand WEGA, In short the solution is, The LAMP needs replacement. Replace the lame and it will work fine again.
Thanks.
Dec 04, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Red light blinks5 times stops & does it repeatly sony KDF-60WF655
5 times red light blinks in Sony KDF-60WF655 shows problem with ballast supply that needs to be replaced.
If you are handy with electronics stuff repair and have service manual copy then can replace it.
Be Aware: electric shock risk is involve in TV repair.
Or contact local TV tech to fix it.
Need further help, let me know please.
Thanks.
Sep 22, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv turns off and on
The first time my lamp needed replaced, the red light came on as well. This time my tv did the same thing, but after talking to my tv repair man he thought it was the lamp. He said that if you use your tv often then the lamp probaly needs to be changed after two or three years. I replacedmy bulb and it corrected the problem and I MUCH BETTER PICTURE.
Dec 29, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony kdf-60wf655
There is a lamp driver error in your TV set. Most likely the ballast circuit for the bulb. Depending on who you take the set to, you will pay anywhere from 300 to 500 bucks to have this set repaired. This is why i recommend an extended warranty on all of these types of TV sets. This repair will involve replacing a board, and it could be one out of three of the differant boards that control the lamp. good Luck.
Jul 21, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
380 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
