Question about Kenmore 73262 / 73264 / 73269 Top Freezer Refrigerator
Kenmore 10672206200 Blows air but freezer and refrigerator not working at all what can be wrong ??
  • 39 Answers
Sounds like the relay and or overload on the comprsor have are bad.
Pull refrigerator out and check to see if the compresor is running either by listening or feeling. If compresor is not running the part on the side of it that is attatched is bad and you will need to replace. If I helped you in resolving your problem please rate my assistance.Thanks !
Posted on Aug 25, 2010
We have a Kenmore Bottom Mount Refrigerator. The freezer cold but the refrigerator part is warm. Model Number is 596.6998. How do we fix it. We have removed the grille and vacummed it.
Is the fan that blows cold air from freezer to refrigerator running? And is the mechanism that controls the doorway allowing air into refrigerator working properly?
Jan 11, 2017 | Kenmore Refrigerators
Why is my refridgerator not getting cold? Is there a fan in the freezer of my Kenmore 106.71192101?
There will be a fan in the freezer section that blows the cold air to the FF section. It could be bad or could be frozen/iced up. Remove the cover of the evaporator in the freezer section fan to inspect. You should hear the fan running. Open the door and push in and hold the door switch to activate the fan.
Aug 08, 2014 | Kenmore Refrigerators
I can not locate the fan that blows to lower part of the refrigerator
In most older reefers, the fan in the back of the freezer does the entire job. It blows cold air through a duct that leads to the ******. If you have no cold air in the ******, but your freezer is still cold...but barely, your fan is shot.
May 02, 2012 | Kenmore 18.2 cu. ft. Top Freezer...
My Kenmore side by side refrigeratro model #50593003 went out. The fan blows cool air, not cold, the freezer doesnt work nor does the refrigerator side. What do I do?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 29, 2011 | Refrigerators
ON MY KENMORE SIDE BY SIDE REFRIGERATOR THE FRIDGE ISNT GETTING COLD BUT MY FREEZER IS FINE
Check to see if the air flow vents are not being blocked. The refrigerator side sucks air from the freezer side and blows it through vents on the side top and is controled by a thermostat marked, usually Refrigerator Cooling. If your thermostat is off, then no air, if the thermostat is kaput, then no air.
Dec 12, 2010 | Kenmore Refrigerators
I have a Kenmore side by side refrigerator, model 51673. The freezer works OK but the refrigerator side is NOT working. Advice?
It could possibly be the fan, located in the freezer compartment.  That blows the cold freezer air into the ducts that go to the refrigerator side.
Aug 25, 2009 | Refrigerators
My kenmore side by side,freezer part is working good but no cold in the refrigerator side ,can any one help me?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Fridge is not cold and freezer is not frozen
check to make sure the fan that blows cold air from the coils of freezer is working. If its not that could cause the freezer to be cool also.
Nov 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Kenmore Trio refrigerator (#596.76502500) is not working. The temp is 76degrees. The freezer seems to be working fine. I have switched it off at the circuit breaker and restarted it after 10 min. The...
The fan that blows cold air from the freezer to cool the refrigerator is not working. If your a little handy with tools its an easy fix. Its located in the freezer. Open your freezer door take off the steel panel at the back of the inside of the freezer. After you remove the panel you will see the fan the blows the cold air up to the Frig. A quick trip to a local appliance store for a new fan with do the trick. Put in the new fan 100% fixed even better than new because the orginal part is defective Kenmore should have recalled them. I have the same frig and its been perfect since I repaced my failed fan.
Aug 04, 2008 | Kenmore Refrigerators
Kenmore 73262 / 73264 / 73269 Top Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
